Thank you for that Steve.
I have pg 9.1.8 and 2.0 installed and I am trying to build the
sew-devel-2_0 branch. When I run "cmake -DWITH_TSP=ON -DWITH_DD=ON ."
I get the following errors :
CMake Error: Target astar has dependency information when it shouldn't.
Your cache is probably stale. Please remove the entry
astar_LIB_DEPENDS
from the cache.
CMake Error: Target dijkstra has dependency information when it shouldn't.
dijkstra_LIB_DEPENDS
from the cache.
CMake Error: Target shooting_star has dependency information when it shouldn't.
shooting_star_LIB_DEPENDS
from the cache.
CMake Error: Target trsp has dependency information when it shouldn't.
trsp_LIB_DEPENDS
from the cache.
Looking at the CMakeCache.txt file, these lines are :
//Dependencies for target
astar_LIB_DEPENDS:STATIC=
dijkstra_LIB_DEPENDS:STATIC=
routing_LIB_DEPENDS:STATIC=
shooting_star_LIB_DEPENDS:STATIC=
trsp_LIB_DEPENDS:STATIC=
I don't know how to fix these errors. Would deleting these lines be ok ?
Thanks in advance
Frédéric Bonifas
+33672652807 skype:fredericbonifas
2013/3/13 Stephen Woodbridge <woodbri@swoodbridge.com>:
On 3/13/2013 6:12 PM, Stephen Woodbridge wrote:
I just pushed today's changes into my branch and only have run the build
on Linux, but I in theory have it coded to install as an extension or
not on pre postgresql 9.1.
None of the SQL code has been changed yet, so you should be able to do a
create extension to install it, it will probably fail because of
function names and stuff like that.
My next steps are:
* pull it back to mingw and see what breaks there and fix that
* install it on my postgresql 8.3/8.4 and see if it works there
* if it does, I'll create TAG or branch to keep a stable version at that
state
* start looking into the issues of running it with postgis 2.x and pg9.2
Corrected!
A couple of points for anyone that wants to play with this. The first being
don't expect too much this is still a work in progress and has not been
tested.
git clone git@github.com:pgRouting/pgrouting.git
cd pgrouting
# Doh! I forgot this most important step ##############
git checkout sew-devel-2_0
# this requires cmake version 2.8.10
make
# assuming everything worked with out any issues you can see
# the install targets here
ls lib
librouting_dd.so librouting_tsp.so pgrouting--1.0.7.sql.in README
librouting.so pgrouting--1.0.7.sql pgrouting.control
# make install will place *.so into pg_config --pkglibdir
# and *.{sql,control} will get placed in either:
# `pg_config --sharedir`/extension/ >= pg 9.1
# or /usr/share/pgrouting/ < pg 9.1
sudo make install
Have fun,
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
