Made some major progress today. On mingw64, I can now build, and install on pg 9.2 with postgis 2.0. I tested the trsp function only with success.
I think my next steps are:
1. check things back on linux and in pg 8.4
2. review all the sql code for changes like adding st_ to function
3. setup mingw32 and test it here
4. look into postgis 2.2
5. package up the windows support
6. start looking at pgrouting 2.0 changes
-Steve
Works as follows:
createdb mydb
psql mydb
create extension plpgsql;
create extension postgis;
create extension pgrouting;
\i core/trsp/test/trsp-test-data.sql
select * from turn_restrict_shortest_path(
'select eid as id, source::integer, target::integer,cost, reverse_cost from edges1',
1, -- edge_id for start
0.5, -- midpoint of edge
6, -- edge_id of route end
true, -- directed graph?
true, -- has_reverse_cost?
null); -- no turn restrictions
1, -- node_id of start
5, -- node_id of end
-- include the turn restrictions
'select to_cost, teid as target_id, feid||coalesce('',''||via,'''') as via_path from restrictions1');
\q
