Hi All,
In looking at the 2.0 branch on GitHub, the documentation to prep for install points to http://pgrouting.org/docs/1.x/install.html but does not indicate the GAUL is no longer a dependency. GAUL is no longer a dependency, correct?
Best,
Steve
On 5/10/2013 9:44 AM, Stephen Mather wrote:
Hi All,
<https://github.com/pgRouting/pgrouting/tree/sew-devel-2_0>, the
Correct, GAUL, it not a dependency on 2.0, I'll open a ticket to clean up the doc.
-Steve
On Fri, May 10, 2013 at 11:01 PM, Stephen Woodbridge <
Hi All,
<https://github.com/pgRouting/**pgrouting/tree/sew-devel-2_0<https://github.com/pgRouting/pgrouting/tree/sew-devel-2_0>>,
the
http://pgrouting.org/docs/1.x/**install.html<http://pgrouting.org/docs/1.x/install.html>but does not indicate the
the doc.
The link to the docs in the Readme goes to the website and of course the
website is for the current version.
I would just remove the two links at the beginning of Readme.md and write
the requirements directly into the file.
Daniel
-Steve
______________________________**_________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
