Already quickly mentioned in a previous post [1], some of the pgRouting developers think that it might be the right time to get started with a new major release.
There are several reasons for that, such as renaming functions (think about “assign_vertex_id” or “shortest_path_shootingstar_directed”) or getting rid of the troublesome CGAL dependency, not to forget compatibility with PostGIS 2.0. Furthermore pgRouting will get some new functions in the next months thanks to Jay’s and Kishore’s great work during GSoC. We think there could be a better way to put together all the functions.
So if you want to back this plan, give some comment, add a request or new idea, … just write to the Wiki or to the mailing list.
If you want to participate and contribute, even better!
I want to contribute to this effort and want to cover every piece of
code with unit tests. Having a solid set of tests gives the confidence
to accomplish the envisioned goals. I wish to hear criticisms on the
testing framework from the other developers so that it can be altered
to fit the actual needs.
Thanks & Regards,
J Kishore kumar.
On Sun, Jun 19, 2011 at 11:27 PM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi list,
major release.
"assign_vertex_id" or "shortest_path_shootingstar_directed") or getting rid
months thanks to Jay's and Kishore's great work during GSoC. We think there
To keep this post short I created a Wiki page on GitHub for collecting ideas
and feedback: https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan (should be
editable by everyone)
idea, ... just write to the Wiki or to the mailing list.
Daniel
