I think that you all have seen this but here is the description of the way
I'm trying to use git.
http://nvie.com/posts/a-successful-git-branching-model/
Worth
_____
[mailto:pgrouting-dev-bounces@lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Thursday, May 30, 2013 8:38 PM
To: pgRouting developers mailing list
Subject: Re: [pgrouting-dev] pgRouting Release Process Checklist
On Fri, May 31, 2013 at 5:23 AM, Stephen Woodbridge
<woodbri@swoodbridge.com> wrote:
Daniel, et al,
I have taken a first pass at defining a pgRouting Release Process Checklist
in the Wiki:
https://github.com/pgRouting/pgrouting/wiki/pgRouting-Release-Process-Checkl
ist
We need to review and expand on this list and I would like to see each step
documented in enough detail that someone not familiar with the process could
follow the check list and cut a release of a new version.
Thanks, Steve!
I have added a few points and made a few modifications.
Github actually already provides source tarballs if there is a release tag.
I also think that a stable release will go to master branch, right?
For example I do not know who (email addresses) needs to be notified?
I think we should see that everyone, who wants to be notified is subscribed
to the right channels.
We need to had what is our version/tag naming conventions?
I think this became a common schema and I would like to use it:
http://semver.org/
"Wrong" version names like "1.05" make packaging unnecessarily complicated
(lessons learned from Ubuntu packages ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
How do we know when it is appropriate to make a tag or a release?
I would say we make a tag when we make a release.
So the question is when we make a release:
For "alpha", "beta" and "rc" it should be OK if the source is at least
passing the tests.
For a stable release I would say, when there are no more tickets for that
milestone in the issue tracker and so complaints about the last RC.
We have put a lot of work into making our project consistent internally, and
I want to make sure that we have repeatable processes so we are consistent
externally as we make releases.
The day before I tried to switch branch names by making a "develop" branch
from master and merging "sew-devel-2_0".
There was no problem, so I think I will do this change when Boston is
sleeping.
Daniel
Georepublic UG & Georepublic Japan
eMail: <mailto:daniel.kastl@georepublic.de> daniel.kastl@georepublic.de
Web: <http://georepublic.de/> http://georepublic.de
_____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.3343 / Virus Database: 3184/6369 - Release Date: 05/30/13
