Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting version 3.5.1
The latest release is available at [1]
For discussions on the release, go to [2]
To see all issues & pull requests closed by this release, see the Git closed milestone for 3.5.1 on Github. [3]
Documentation fixes
Changes on the documentation to the following:
- pgr_degree
- pgr_dijkstra
- pgr_ksp
- Automatic page history links
- using bootstrap_version 2 because 3+ does not do dropdowns
Issue fixes
- #2565: pgr_pgr_lengauerTarjanDominatorTree triggers an assertion
SQL enhancements
- #2561: Not use wildcards on SQL
pgtap tests
#2559: pgtap test using sampledata
Build fixes -
Fix winnie build
Code fixes -
Fix clang warnings
Grouping headers of postgres readers
To update your database
Download the packaged version from your operating system, and use this command in the database:
ALTER EXTENSION pgrouting UPDATE TO “3.5.1”;
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2]. https://github.com/pgRouting/pgrouting/discussions/2571
[3]. https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.5.1%22
pgRouting Team.
