PostGIS 2.0 is not supported for Pg 9.3. We had patched up 2.1 with the
htup_details.h to work with 9.3 (pgRouting is fine I think because we had
already patched it for 9.3 when I noticed the same issue a while ago)
-----Original Message-----
[mailto:postgis-devel-bounces@lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Tuesday, April 15, 2014 3:33 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] Issue installing postgis-2.0 in Pg 9.3
Hi devs,
I just noticed that the pgrouting travis instance is failing when we try to
create a postgresql 9.3 and install postgis-2.0 into it with the follow
error:
ERROR: could not load library
"/usr/lib/postgresql/9.3/lib/postgis-2.0.so":
/usr/lib/postgresql/9.3/lib/postgis-2.0.so: undefined symbol: GETSTRUCT
This is running Ubuntu precise? and probably packages from the Ubuntu GIS
ppa from launchpad.
So two questions:
1. Is this known/fixed/etc? Are we just out of date on travis?
2. For pgRouting, will I need to add something like:
Thank you for looking into this and relaying that information.
Daniel,
When you have a chance it sounds like we need travis updated to only support the matrix below.
-Steve
On 4/15/2014 4:44 PM, Paragon Corporation wrote:
Steve,
Woodbridge
Hi devs,
error:
ppa from launchpad.
So two questions:
Daniel,
-Steve
Steve,
error:
“/usr/lib/postgresql/9.3/lib/postgis-2.0.so”:
ppa from launchpad.
So two questions:
