Hey all,
I am trying to use postgresql to build the network database, but got a problem when I ran “createdb -U postgres -T template_routing routing”.
Error message:
“createdb: could not connect to database postgres: FATAL: password authentication failed for user “postgres””
I already used “passwd” to change the password of “postgres” and used “trust” to replace “md5” in pg_hba file.
Any ideas?
Jinfu
On 5/24/2012 10:11 AM, Jinfu Leng wrote:
Hey all,
problem when I ran "createdb -U postgres -T template_routing routing".
Error message:
"createdb: could not connect to database postgres: FATAL: password
authentication failed for user "postgres""
I already used "passwd" to change the password of "postgres" and used
"trust" to replace "md5" in pg_hba file.
1. you have to restart postgresql after changing the pg_hba file.
2. you might try adding -h localhost to you command.
-Steve
Hey Steve,
Thanks, I restarted my computer, and then it worked.
Jinfu
On Thu, May 24, 2012 at 10:24 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hey all,
Error message:
- you have to restart postgresql after changing the pg_hba file.
- you might try adding -h localhost to you command.
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Hey,
I got a new problem now,
When I was trying to create the database template with the .sh, I got the error message:
“/usr/share/postlbs/routing_core.sql: No such file or directory”
I found that “postlbs” folder did not exist in my disk. According to some archived emails, this is because “pgrouting” was not installed successfully. But I think I have correctly compiled and installed it.
In addition, I found the “.sql” files located in my “usr/share/pgrouting” folder. So for creating the database template, I can change the path in the “.sh” file and use these “.sql”, but I am not sure if this will ruin the later steps.
Jinfu
Hey all,
Error message:
-Steve
You can search for files on your systems with the command locate like:
locate routing_core.sql
If you compiled and installed pgrouting then it might have been install under /usr/local/share/postlbs/ check and see if it is there.
-Steve
On 5/24/2012 11:13 PM, Jinfu Leng wrote:
Hey,
the error message:
"/usr/share/postlbs/routing_core.sql: No such file or directory"
I found that "postlbs" folder did not exist in my disk. According to
some archived emails, this is because "pgrouting" was not installed
In addition, I found the ".sql" files located in my
"usr/share/pgrouting" folder. So for creating the database template, I
can change the path in the ".sh" file and use these ".sql", but I am not
Jinfu
Hey all,
got a
routing".
Error message:
used
-Steve
______________________________ _________________
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
CMake scripts in master branch should install the .sql files into /usr/share/pgrouting.
But “official” versions install the files in /usr/share/postlbs. The latter was decided in the early days of pgRouting, but “pgrouting” as directory name made more sense.
Daniel
On Fri, May 25, 2012 at 12:36 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
-Steve
Hey,
the error message:
Jinfu
<woodbri@swoodbridge.com mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)> wrote:
Hey all,
got a
routing”.
Error message:
used
-Steve
pgrouting-dev@lists.osgeo.org mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
