Hello all,
I created the database “routing” from the “template_routing”, and downloaded the .osm file of London. But I got a problem when I was trying yo import this .osm file to the database.
command:
“osm2pgrouting -file “London.osm” -conf “/usr/share/osm2pgrouting/mapconfig.xml” -dbname routing -user postgres -clean”
error message:
“connection failed”
Any ideas?
Thanks a advance.
Jinfu
Hello,
From the text of the error message, it appears your having a problem
connecting to your database, its not a pgroute package error but rather a
postgres error.
What happens if you try
psql -d routing -U postgres
This should connect directly to your database without using any of the
routing software.
Jinfu Leng wrote:
Hello all,
I created the database "routing" from the "template_routing", and
command:
"osm2pgrouting -file "London.osm" -conf
"/usr/share/osm2pgrouting/mapconfig.xml" -dbname routing -user postgres
-clean"
error message:
"connection failed"
Any ideas?
Thanks a advance.
Jinfu
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Hi Jinfu,
Look at the “Note” in the workshop: http://workshop.pgrouting.org/chapters/osm2pgrouting.html#run-osm2pgrouting
When you don’t need to care about server security you can set the settings in pg_hba.conf to trust.
Daniel
On Wed, May 30, 2012 at 8:34 AM, Dave Potts <dave.potts@pinan.co.uk> wrote:
Hello,
postgres error.
routing software.
Jinfu Leng wrote:
Hello all,
command:
-clean”
error message:
“connection failed”
Any ideas?
Thanks a advance.
Jinfu
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Hey Daniel, Dave,
Thanks. The problem is solved by settings the pg_hba.conf to trust.
But I got some error messages like:
“We DON’T need a way of type and class
We need a way of type highway and class steps
We need a way of type highway and class footway
We need a way of type highway and class footway”
Do these errors matter? Or I can ignore them and go to the next step?
Thanks again,
Jinfu
On Wed, May 30, 2012 at 10:44 PM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Jinfu,
Daniel
Hello,
postgres error.
routing software.
Jinfu Leng wrote:
Hello all,
command:
-clean”
error message:
“connection failed”
Any ideas?
Thanks a advance.
Jinfu
Hi Jinfu,
As far as I remember this is only a log message. I think it would be better to reduce the number of messages.
At the end it should tell you the number of imported road segments.
Daniel
On Wed, May 30, 2012 at 6:57 PM, Jinfu Leng <logicnut@gmail.com> wrote:
Hey Daniel, Dave,
Thanks again,
Jinfu
Hi Jinfu,
Daniel
Hello,
postgres error.
routing software.
Jinfu Leng wrote:
Hello all,
command:
-clean”
error message:
“connection failed”
Any ideas?
Thanks a advance.
Jinfu
Hey Daniel,
I tried the existing algorithm based on the road data imported from .osm file. and it worked.
Right now I have one question:
How to match the “source” and “target” in table “way” with the node in table “nodes”?
Jinfu
On Thu, May 31, 2012 at 3:26 AM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Jinfu,
Daniel
Hey Daniel, Dave,
Thanks again,
Jinfu
Hi Jinfu,
Daniel
Hello,
postgres error.
routing software.
Jinfu Leng wrote:
Hello all,
command:
-clean”
error message:
“connection failed”
Any ideas?
Thanks a advance.
Jinfu
