Hey,
I am trying to install pgrouting, but get some problems:
When I was running this command “cmake -DWITH_TSP=ON -DWITH_DD=ON”, I get the error messages said “GAUL” and “Postgresql” are required. Then I tried to install “GAUL”, and get the message that “s-lang” is required. I downloaded the source code of “s-lang”, but did not figure out how to install it. I also checked “synaptic package manager”, and found that “postgresql-8.4” was already existed.
I am using Ubuntu 10.04, 64 bits.
Many thanks.
Jinfu
On 5/17/2012 4:31 PM, Jinfu Leng wrote:
Hey,
When I was running this command "cmake -DWITH_TSP=ON -DWITH_DD=ON", I
get the error messages said "GAUL" and "Postgresql" are required. Then I
tried to install "GAUL", and get the message that "s-lang" is required.
I downloaded the source code of "s-lang", but did not figure out how to
install it. I also checked "synaptic package manager", and found that
"postgresql-8.4" was already existed.
Ok, you need to install some of the dev packages.
sudo apt-get install postgresql-server-dev-8.4
sudo apt-get install libslang2 libslang2-dev
You can use apt-cache search <string> to search for packages based on <string> eg: apt-cache search slang
-Steve
Hey Steve,
Thanks for your help. It, finally, works. Right now I am trying to use some test data to learn how to use it. I will let you know once I have some problems.
Jinfu
On Fri, May 18, 2012 at 4:45 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hey,
You can use apt-cache search to search for packages based on eg: apt-cache search slang
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
