Awesome! that works now just fine and dandy. Thank you for sorting that out as it saved me a lot of time that I would rather put toward moving the other changes along.
Hi Stephen,
I have updated the MinGW32/64 build instruction,
so, could you retry from boost build?
(Sorry, gcc PATH settings is not necessary, because msys.bat path
settings seems to be inherited by command prompt.)
https://github.com/sanak/pgrouting4w/commit/e5ae697b3cb545b002702eda62c2909382ae4521
2013/3/13 sanak <geosanak@gmail.com mailto:[geosanak@gmail.com](mailto:geosanak@gmail.com)>
Hi Stephen,
Oops, sorry, my boost_1_46_1/tools/build/bjam.log shows “msvc10”
which I have installed…
I will check after returning from work. (about 12 hour later)
2013/3/13 Stephen Woodbridge <woodbri@swoodbridge.com
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>
OK, it looks like I have solved ISSUE 2, I think this was caused
because I built boost with the 32 bit model in the 64 bit
environment. I still can not not get ISSUE 1 to resolve and I
had to rebuild it using the bjam I built under 1_51.
To fix ISSUE to:
- rebuilt boost_1_46_1 as 64 bit model using bjam from 1_51
- rebuild CGAL
- rebuild pgrouting
So I have at least on cuild of pgRouting
So making progress in small steps ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
If you have any additional thoughts on getting boost to build
they would be appreciated.
In my msys.bat shell, I have:
PATH=/c/ming64/mingw64/bin/:/__home/woodbri/bin:.:/usr/local/__bin:/mingw/bin:/bin:/c/oracle/__product/10.2.0/db_1/bin:/c/__Windows/system32:/c/Windows:/__c/Windows/System32/Wbem:/c/__Windows/System32/__WindowsPowerShell/v1.0/:/c/__Program
Files (x86)/QuickTime/QTSystem/
-Steve
On 3/12/2013 11:34 AM, Stephen Woodbridge wrote:
Hi Sanak,
I’m still have an issue with this. Hopefully I followed your
changes
correctly:
In my msys.bat shell I added the to the path:
/c/ming64/mingw64/bin/, I
have /c/ming64/ and /c/ming32/ trees setup so I can build on
either.
start cmd
gcc -v # is found and run
bootstrap.bat gcc # fails
bootstrap.bat mingw # fails
exit
$ cat tools/build/bjam.log
Using ‘msvc’ toolset.
c:\ming64\projects\boost_1_46___1\tools\build\v2\engine\src>if
exist
bootstrap rd /S /Q bootstrap
c:\ming64\projects\boost_1_46___1\tools\build\v2\engine\src>md
bootstrap
c:\ming64\projects\boost_1_46___1\tools\build\v2\engine\src>cl
/nologo /GZ
/Zi /MLd /Fobootstrap/ /Fdbootstrap/ -DNT -DYYDEBUG kernel32.lib
advapi32.lib user32.lib /Febootstrap\jam0 command.c
compile.c debug.c
execnt.c expand.c filent.c glob.c hash.c hdrmacro.c
headers.c jam.c
jambase.c jamgram.c lists.c make.c make1.c newstr.c option.c
output.c
parse.c pathunix.c regexp.c rules.c scan.c search.c subst.c
timestamp.c
variable.c modules.c strings.c filesys.c builtins.c md5.c
pwd.c class.c
w32_getreg.c native.c modules/set.c modules/path.c
modules/regex.c
modules/property-set.c modules/sequence.c modules/order.c
I looked at tools/build/v2/engine/src/__build.bat but I’m
not very
familiar with windows bat files.
-Steve
On 3/12/2013 9:15 AM, sanak wrote:
Hi Stephen,
I updated MinGW32/64 build instruction to my “mingw” branch,
and checked that MinGW64-bit build successed. (but not
tested)
https://github.com/sanak/__pgrouting4w/commit/__2a660524b53bcd80005e52917af5b3__2b31749559
<https://github.com/sanak/pgrouting4w/commit/2a660524b53bcd80005e52917af5b32b31749559>
so, retry from boost build about ISSUE1. (Thanks Pieter!)
2013/3/12 Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.__com
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)>>
I’m stuck at the moment trying to link the
pgrouting driving
directions module using mingw 64 bit. See the
issues below. So if
anyone has any thoughts on this it would be
appreciated. I will
check the current state of the files into my branch
in the morning
here (GMT-5) if you are setup to reproduce this. It
is too late to
do it with a clear head tonight. I’ll also move it
back to Linux and
try again there as I have changed a lot of files.
-Steve
I have followed Sanak’s directions from:
https://github.com/sanak/____pgrouting4w/blob/master/BUILD.____mingw64
<https://github.com/sanak/__pgrouting4w/blob/master/BUILD.__mingw64>
<https://github.com/sanak/pgrouting4w/blob/master/BUILD.mingw64>>
ISSUE 1:
I first installed boost_1_51.zip but ran into
problems compiling so
installed boost_1_46_1.zip as he suggested. I was
able to bootstrap
1_51 and get a bjam.exe without a problem. But I
could not get
1_46_1 to bootstrap ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All
rights reserved.
c:\ming64\projects\boost_1_46_____1>bootstrap.bat mingw
Building Boost.Jam build engine
‘cl’ is not recognized as an internal or external
command,
operable program or batch file.
Failed to build Boost.Jam build engine.
Please consult bjam.log for furter diagnostics.
You can try to obtain a prebuilt binary from
http://sf.net/project/____showfiles.php?group_id=7586&____package_id=72941
<http://sf.net/project/__showfiles.php?group_id=7586&__package_id=72941>
<http://sf.net/project/showfiles.php?group_id=7586&package_id=72941>>
Also, you can file an issue at http://svn.boost.org
Please attach bjam.log in that case.
So I built 1_46_1 using the bjam.exe that I built
in 1_51 and it
seems to have worked ok, but maybe that is part of
the problem.
ISSUE 2:
Is the follow mess from the linker
Scanning dependencies of target routing_dd
[ 80%] Building C object
core/driving_distance/src/____CMakeFiles/routing_dd.dir/____alpha.c.obj
[ 86%] Building CXX object
core/driving_distance/src/____CMakeFiles/routing_dd.dir/____alpha_drivedist.cpp.obj
In file included from
c:/ming64/projects/pgx64/pg92/____include/postgresql/server/__pg___config_os.h:37:0,
from
c:/ming64/projects/pgx64/pg92/____include/postgresql/server/c.__h:__87,
from
c:/ming64/projects/pgx64/pg92/____include/postgresql/server/____postgres.h:47,
from
c:/ming64/projects/pgrouting/____core/driving_distance/src/____alpha.h:27,
from
c:/ming64/projects/pgrouting/____core/driving_distance/src/____alpha_drivedist.cpp:46:
c:\ming64\mingw64\bin../lib/____gcc/x86_64-w64-mingw32/4.5.4/../…/…/…/x86_64-w64-__mingw32/__include/winsock2.h:__13:2:
warning: #warning Please include winsock2.h before
windows.h
[ 93%] Building CXX object
core/driving_distance/src/____CMakeFiles/routing_dd.dir/____boost_drivedist.cpp.obj
[100%] Building C object
core/driving_distance/src/____CMakeFiles/routing_dd.dir/____drivedist.c.obj
Linking CXX shared library
…/…/…/lib/librouting_dd.dll
Creating library file:
…/…/…/lib/librouting_dd.____dll.a
c:/ming64/msys/local/lib/____libboost_thread-mgw45-mt-1_46_____1.a(thread.o):
duplicate section
`.data$_ZTVN5boost16exception_____detail10clone_implINS0_____19error_info_injectorISt9bad_____allocEEEE[vtable
for
boost::exception_detail::____clone_impl<boost::exception_____detail::error_info_injector<____std::bad_alloc>
]’ has different size
c:/ming64/msys/local/lib/____libCGAL.a(all_files.cpp.obj):____all_files.cpp:(.text+0xf898):
undefined reference to
`boost::system::generic_____category()’
c:/ming64/msys/local/lib/____libCGAL.a(all_files.cpp.obj):____all_files.cpp:(.text+0xf8a4):
c:/ming64/msys/local/lib/____libCGAL.a(all_files.cpp.obj):____all_files.cpp:(.text+0xf8b0):
`boost::system::system_____category()’
collect2: ld returned 1 exit status
make[2]: *** [lib/librouting_dd.dll] Error 1
make[1]: ***
[core/driving_distance/src/____CMakeFiles/routing_dd.dir/all]
Error 2
make: *** [all] Error 2
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
<mailto:pgrouting-dev@lists.__osgeo.org
mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)>
http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev <http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>__>
pgrouting-dev@lists.osgeo.org mailto:[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
