strk, Vicky,
I tried to integrate this pull request into my local develop branch but the test is failing. I suspect that it only needs the test results updated.
src/common/test/createTopology-any-01.test -- test file
src/common/test/createTopology-any-01.rest -- result file
I can update the result file if you can confirm that the command is actually working as expected. Then I will commit and push the change into develop and into develop-2_0_1
One concern is whether we need to dynamically change the reporting level when this executes so we don't spew noisy messages that will only confuse the users.
If I have time tonight, I'll take a closer look at the results myself.
-Steve
