I wrote some codes for the new algorithm, but I do not know how to integrate it to pgRouting. I am not familiar with the Linux programming. I mean, which files should I edit, and then when I install pgRouting again, the new source code will be compiled and integrated.
pgRouting uses Cmake (www.cmake.org) and it’s a good idea to look into the Cmake documentation. There are probably things that can be done even better with the current Cmake install files.
pgRouting has two types of “algorithms”: those part of “core” and those part of “extra”. To install algorithm part of “extra” a compile flag like “–with-tsp” is used.
The reason to have “core” and “extra” was, that some algorithms required other libraries such as GAUL or CGAL and it was sometimes a bit complicated to get them installed. So we put them into “extra” that pgRouting could be compiled more easily for those, who only needed shortest path functions.
On the long term it would be nice to get rid of dependencies like CGAL and we could forget about “extra” and just compile all function.
So I would propose that every algorithm that has no new dependencies should be compiled by default and doesn’t get a compile flag.
