Hey all,
I'm working on a ruby wrapper for some pgRouting 2.0 functions that
I'm calling RbRouting. This is based on some ruby code that I pulled
out of ridethecity.com and made a bit more generic. Currently, I've
defined classes to generate TRSP, Dijkstra, and A* shortest paths, as
well as a method to run osm2pgrouting. (I haven't actually tested the
restrict_sql part of TRSP yet, but in theory it should work!)
My goal is to provide this plus a generic version of the logic
ridethecity.com uses to generate its turn-by-turn directions, too,
possibly via a separate class or plugin gem.
Here's the repository: https://github.com/jordanderson/rb_routing
I haven't published this to rubygems yet as it's still pretty rough
around the edges and has no documentation, but I'd appreciate your
feedback, issue reporting, or pull requests!
Jordan
On 3/11/2014 12:34 AM, Jordan Anderson wrote:
Hey all,
Jordan
Hi Jordan,
Thanks for your interest and your contribution.
I just added a new section to our wiki called "Friends of pgRouting"
https://github.com/pgRouting/pgrouting/wiki
and added a pointer to your project.
I don't use Ruby so I'm not much help there but I bet you will get some others that are interested.
Best regards,
-Steve
