Hi Markus,
osm2pgrouting also loads data into a table called way_tag that
maintains the relationships between ways and multiple tags.
Jordan
Date: Fri, 18 Feb 2011 11:59:16 +0100
Subject: [pgrouting-dev] My questions again:-)
To: "pgrouting-dev@lists.osgeo.org" <pgrouting-dev@lists.osgeo.org>
Message-ID:
<7F35DC3EAB7D654E8F74E5EA41A7EA07B3103DB59B@MOLDAU.medewerker.fontys.local>Content-Type: text/plain; charset="us-ascii"
Hey,
I try to ask my questions again:-)
1.
when I try to import Bayern.osm or Germany.osm with osm2pgrouting, the script stops when Trying to load the data and trying to parse the data. Is that a common error?
Barcelona.osm from the workshop works with no problems. Did I forgot anything?2.
I played a little bit around with OSGEO live tools.
I Understand that mapconfig.xml defines the relevant tags and that you have to add costs to these tags.
I did not understand if for example a way has a tag bridge=yes and a tag highway=motorway this way is saved two times in the db because every way has only one class_id.
how is it handled if there are two relevant tags for one way?Best regards,
