I'll have look and let you know as soon as I can put my hands on it.
On Mon, Jul 2, 2012 at 9:41 AM, "Christophe Damour (SIGéal)" <sigeal@sigeal.com <mailto:sigeal@sigeal.com>> wrote:
I totally agree with both of you, Daniel and Mario.
I too was a bit confused by existing wrappers when I began to use
pgrouting.
Wrappers should add extra functionalities.
A function that accept source and target x/y would indeed be
usefull, especially if it can return the first and last edge cut
at the actual projection of source and target x/y. I will need
such a function soon, so I will have to work on it...
This is indeed an often requested "feature". But it can be more tricky than it initially looks like.
There is some example you can start with: https://github.com/pgRouting/pgrouting-contrib/tree/master/wrapper
For wrappers "shipped" we should define some criteria. As more we have as more needs to be documented and maintained. Instead a tutorial or a few recipes to help users to write and modify their own custom wrappers might make more sense.
Daniel
Any hints appreciated.
Christophe
Le 02/07/2012 09:28, Mario Basa a écrit :
Daniel,
I agree. Right now it really is quite confusing which function
to use,
and the description of each function is not also very helpful.
I am curious though why is it that there is no sp function that
accepts source_x,source_y and target_x,target_y parameters
similar to
that of driving_distance. This I think, will be very useful.
Mario.
On Mon, Jul 2, 2012 at 4:11 PM, Daniel Kastl
<daniel@georepublic.de <mailto:daniel@georepublic.de>> wrote:
Hi Mario,
In my opinion I would drop functions like the one you
mentioned and reduce
the number of wrappers as much as possible.
I think a good and useful wrapper function is one, that
selects a BBOX
containing start and end point and returns records with
geometries.
Then everyone can modify it as needed. I don't think we
should simplify
those basic wrappers and make assumptions like naming the
cost column
"length" or so.
What do you think?
Daniel
On Mon, Jul 2, 2012 at 9:02 AM, Mario Basa
<mario.basa@gmail.com <mailto:mario.basa@gmail.com>> wrote:
Hello,
The core wrapper functions have
dijkstra_sp_delta_directed
astar_sp_delta_directed
with "length" hard coded as cost for some reason.
While astar_sp_delta_cc has a cost column parameter,
but all it does
is call astar_sp_delta_cc_directed with
reverse_cost=false,directed=false.
There is also no dijkstra_sp_delta_cc with a cost
column parameter, so
a user has to rename the column containing the cost
value to "length"
to use this clipping function. Etc....
Personally I am getting confused with all these
functions and would
like to just trim it down to dijkstra_sp_delta and
astar_sp_delta with
a cost column parameter along with reverse_cost and
directed
parameters.
Opinions?
Mario.
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
<mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
