Hello there,
I am working on one of my projects which requires the implementation of a function/query which uses data from a postgresql database. To do so I need to generate a "my_function.so" from "my_function.c",which uses cpp functions.I am facing a problem in linking "my_function.c" with the cpp files(where the cpp functions are defined) and generate a "my_function.so" which is used to create a postgresql function.
"my_cpp_header.h":-
#ifndef DIJKSTRA_FUNCTION_H_
#define DIJKSTRA_FUNCTION_H_
#ifdef __cplusplus
extern "C" {
#endif
int compute_dijkstra(int source,int target,Edge *edges,int num_vertices,int num_edges,Edge **path);
#ifdef __cplusplus
#endif
#endif
"my_cpp_function.cpp":-
#include "my_cpp_header.h"
definition of the function(in cpp)
I need to generate "my_function.so" from "my_function.c" which uses the above function.
Please help me solving this.
Thanks in advance.
