Hi Daniel, et al,
I have added renaming the pgrouting types to the spreadsheet. But I'm concerned about doing this for a few reasons. If we are going to change the types, this needs to be done first to avoid having to touch all the SQL code twice.
pros:
1. it gives a more consistent naming through the project
cons:
1. this change is more invasive because it propagates into the C code
2. it may break the ability of legacy functions from working with old existing code unless it is possible to define a CAST that would map the new type to the old type like:
create cast (pgr_pathResult as path_result)
without function as implicit;
I have not tried this but it seems like it might work.
Thoughts?
-Steve
Hello,
I think it makes sense to the naming consistent for this release since it will only get harder to change in the future.
On a hopefully related note, is there a reason that path_result does not include an explicit edge order? I'm using row_number() OVER (PARTITION BY routeid) to generate one, but my understanding is that this isn't guaranteed to preserve the correct ordering? I also assume that it's adding considerable overhead to the query.
Best,
Alec
On May 10, 2013, at 11:36 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi Daniel, et al,
pros:
cons:
Thoughts?
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
