On Sat, May 4, 2013 at 4:14 AM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 5/3/2013 2:45 PM, Daniel Kastl wrote:
Over the time several branches were created in the pgRouting
repository.
Some were for Google Summer of Code or development of new
algorithms,
others for packaging and some for working on the new 2.0 release.
As Steve has completed a lot of tasks for a new release, I think
it's
time to do some repository cleanup: mainly get rid of useless
branches
and give them proper names.
I have created a list of the current branches and added comments
(2nd
sheet):
https://docs.google.com/a/__georepublic.de/spreadsheet/__ccc?key=0AiIg1pkkh___MRdGQzOEhyaXlndkN3eHdGNkpyQ0pM__ZFE#gid=4
<https://docs.google.com/a/georepublic.de/spreadsheet/ccc?key=0AiIg1pkkh_MRdGQzOEhyaXlndkN3eHdGNkpyQ0pMZFE#gid=4>
By deleting the Debian packaging related branches, nothing gets
lost. It
was an attempt to automate packaging, but this might be done better.
The most important change would be to introduce a "pgr-1.x" and a
"pgr-2.x" branch, which should be "safe" to use. Releases
(alpha, beta,
RC, stable) would be tagged within these branches.
The "master" branch then would contain the current state of
development.
To achieve this, I would propose to:
1. Branch "master" as "pgr-1.x"
2. Merge "sew-devel-2_0" branch into "master"
3. Then branch "master" as "pgr-2.x"
Does this make sense?
I can see saving the current master as pgr-1.x, this could be used
to create point releases to fix bugs, or to make compatibility
changes for postgres 2.x releases, etc.
My plan was to at some point make my branch the new master, that can
happen as soon as the current master gets save in pgr-1.x
There is no need to create a pgr-2.x branch. The idea it to have the
main development line in master and then to tag branches as
significant points along that development. So the code stream SHOULD
look like:
+--pgr-1.08-o +--pgr-1.09-o
+- pgr-1.x----/---------------/--__---->
master----/---(merge sew-devl-2_0)---\---------->(__pgr-3.0-dev)------>
+--pgr-2.0-beta1-o-pgr-2.0-__beta2-o
etc. the 'o' is were we cut a release.
So we only create a tag when we want to save the current state of
things. We can create branches off the master for feature
development and then they can be merged back into the master like I
have done doe 2.0.
So I think we are saying the same thing.
Hi Steve,
I thought once more about it and what a new pgRouting user might expect,
who wants to compile pgRouting.
Also I remembered this quite popular Git branch model, which I found not
simple enough for small projects, but for some Open Source project it
might be suitable:
http://nvie.com/posts/a-successful-git-branching-model/
Following this branching model has the advantage, that many developers
should be familiar with it and that it should be "good enough". ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Well, I think in Github world the "master" branch is something 99.9
percent of all repositories have, and its's usually the branch displayed
and checked out by default.
So I would say, that as a user you expect that "master" isn't a (broken)
development branch ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
As the article mentions, there may be three types of branches:
* Feature branches
* Release branches
* Hotfix branches
I added a column to the branch list spreadsheet as this is a good
classification that also fits to some of the current branches. It
actually suits to all that are not marked as <drop>.
I think all these branches can be temporary, but there might be reasons
to keep them, ie.:
* They haven't been merged yet (ie. darp branches)
* Google Summer of Code branches to document a students work (ie.
those starting with gsoc-)
* They have been merged to the current version, but some people might
want to make the changes also available for elder releases (ie. trsp)
If we follow the previously mentioned branching model, then we would
create a "develop" branch (maybe from "master"?) and merge
"sew-devel-2_0" into it.
Since we might still support 1.x for some time though I would create an
extra branch for this.
I have modified the Spreadsheet accordingly.
Do you think this is better?
I'm happy following the model on the link you referenced.
We should ask we can save a pdf ot that page in github and reference it in out development standards.
