dear sir,
i m working with an application on pg routing and want your to know that is it possible to carry forward the same with in dot net.
Thanks & Regard
Ranjeet K paswan
dear sir,
Thanks & Regard
Ranjeet K paswan
On 3/14/2013 1:11 AM, Ranjeet Paswan wrote:
dear sir,
Hi Ranjeet,
I'm not sure what you are think about here.
1. do you want to create a .NET application that can make a request to a postgresql database to do routing? then yes this is very easy and straight forward.
2. do you want to move the routing out of the database and into .NET? Then the short answer is no, the longer answer is sure if you want to recode everything in .NET and figure out how to replace all the database functions that are getting done in postgresql and postgis today. I think there are other routing libraries available already in .NET, but maybe not opensource ones.
-Steve
