I'm will to work with you to add something generic to pgRouting, I just don't have time to do 100% of it myself. The coding part is not too hard once you have worked out a design, and then the documentation and test cases take a lot of time.
If you have questions feel free to ask.
Thanks again, Stephen, Daniel.
2013/11/28 Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>>
Hi Paulo,
Sorry, the implementation that I have is was developed for a
specific client and is very much tied to their data and table
structure and I am not allow to distribute it.
I have written up how to do this on a wiki page here:
https://github.com/pgRouting/__pgrouting/wiki/Driving-__Direction-Instructions
<https://github.com/pgRouting/pgrouting/wiki/Driving-Direction-Instructions>
-Steve
On 11/28/2013 9:42 AM, Paulo Figueiras wrote:
Hello, Daniel.
Thank you for your quick reply. Well, for now I wouldn't want to
enrol
myself in such an endeavor
. I would prefer to use something
that is
already done, even if it is much simpler than other routing engines'
driving instructions.
I was reading one thread of your mailing list where you guys
talk about
the solution presented by Stephen Woodbridge, using iMapTools,
and I was
wondering if Stephen's algorithm is accessible for use, or if it
is a
private solution.
Do you know anything about this subject? Thank you very much.
Paulo.
2013/11/28 Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>
<mailto:daniel@georepublic.de>__>
On Thu, Nov 28, 2013 at 8:43 PM, Paulo Figueiras
<paf@uninova.pt <mailto:paf@uninova.pt>
<mailto:paf@uninova.pt>> wrote:
Greetings.
I am a portuguese developer and I just started using
as my routing engine. I chose it because it is very
flexible and
scalable, and it is based on a relational database.
This offers me other types of functionalities that normal
routing engines don't.
Even so, I need a higher-level functionality, namely route
instructions or navigation directions, that pgRouting
does not
provide for now (I think).
I read some forum posts from people that had the same
problem as
me. Some of them are really old (more than 2 years). I
found two
ways of doing that:
- One way is to implement a instruction algorithm,
such as
the one described here:
http://lists.osgeo.org/__pipermail/pgrouting-users/__2011-January/000537.html
<http://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000537.html>
- The other way is to have an external service to
do that,
such as,
http://techbase.kde.org/__Projects/Marble/__RoutingInstructions
<http://techbase.kde.org/Projects/Marble/RoutingInstructions>
Now, my question is that neither one of the approaches
to having
navigation directions from a pgRouting route is
optimized or
well documented.
Are there any new alternatives to these two approaches?
If not,
is there a more developed solution to the route
instructions
issue (commonly called Driving Directions issue) ?
Hi Paulo,
As you have already said, this question came up quite a few
times
already.
I think the reason, why there is no out-of-the-box solution
yet, is,
that it is very difficult (probably impossible) to provide
this kind
of driving instructions in a way that it works for any
(road) network.
And beside the variety of data there are also lots of
languages.
If you (or someone else) is able to draft a concept how to
produce
driving directions in a smart way, that it does not depend on a
specific dataset or language, then such a functionality
would be a
valuable contribution ... which might even attract some
funding ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
<mailto:daniel.kastl@georepublic.de>
<mailto:daniel.kastl@__georepublic.de
<mailto:daniel.kastl@georepublic.de>>
Web: http://georepublic.de/>
_________________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>
<mailto:pgrouting-dev@lists.__osgeo.org
<mailto:pgrouting-dev@lists.osgeo.org>>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Paulo Figueiras <paf@uninova.pt <mailto:paf@uninova.pt>
<mailto:%3Crddc@uninova.pt <mailto:3Crddc@uninova.pt>>>______
cid:image002.jpg@01C8AEC7.__2F6E45A0 <http://www.uninova.pt/>\_\_\_\_
__ __
UNINOVA, Centre of Technology and Systems
Campus da Caparica, Quinta da Torre
2829-516 Monte Caparica, PORTUGAL____
Phone: (+351) 212948312 <tel:%28%2B351%29%20212948312> | Fax:
(+351) 212957786 <tel:%28%2B351%29%20212957786> | Website:
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org>
Paulo Figueiras <paf@uninova.pt <mailto:%3Crddc@uninova.pt>>____
cid:image002.jpg@01C8AEC7.2F6E45A0 <http://www.uninova.pt/>\_\_\_\_
__ __
Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
