Hi All,
Here is my 10th weekly report :
### What did i do this week ?
- I improved the optimizer further more (added one more move to it), however the optimizer currently gets stuck after obtaining a local minima so it will be interesting to observe how the moves switch between themselves and have a order for the moves so that local minima is avoided.
### What will I be working on next week?
- I will test the optimizer for some benchmark test cases [http://web.cba.neu.edu/~msolomon/problems.htm.This](http://web.cba.neu.edu/~msolomon/problems.htm](http://web.cba.neu.edu/~msolomon/problems.htm).This) was mentioned in the previous to do list so i will try it out this weekend.
- Will work towards further improvising the optimizer and also have a look at modifying the current implementation to solve CVRP without time windows.
### Did I meet with any stumbling blocks?
- Not blocked on something but improving the optimizer is a very tricky task .
Link to weekly report : https://github.com/pgRouting/pgrouting/wiki/GSoC-2014-Mukul-Priya-R10
Link to code repository :https://github.com/pgRouting/pgrouting/tree/gsoc-cvrptw
Thanks
Mukul
