Hi All,
This is my report for week 11 (July 23 - July 29).
What did you get done this week?
- Implemented all possible signatures for pgr_dagShortestPath.
- Added documentation files and updated proposed experimental functions.
- Added function’s test files.
Detail and Pull Request can be found at [1] & [2] respectively.
What do you plan on doing next week?
- Check and fix any issues related to the functions added to pgRouting.
- Do changes to the code to make it compatible with develop branch[7].
- Merge work from all three branches.[4][5][6]
- Prepare presentation regarding implemented functions.
Are you blocked on anything?
No, I am not blocked.
The wiki page and current repository/branch can be found at [3] and [4].
[1]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford#week-11-23-july—29-july
[2]. https://github.com/pgRouting/pgrouting/pull/1073
[3]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford
[4]. https://github.com/pgRouting/pgrouting/tree/gsoc-dag_sp
[5]. https://github.com/pgRouting/pgrouting/tree/bellmanFord
[6]. https://github.com/pgRouting/pgrouting/tree/gsoc/parallel-dijkstra
[7]. https://github.com/pgRouting/pgrouting/pull/1070
Best Regards,
Sourabh Garg
IIT BHU, India
