Hi All,
This is my report for week 6 (June 18 - June 24)
What did you get done this week?
- Change function’s name from pgrbellman_ford to pgr_bellmanFord.
- Retrieving negative edges((or all edges) in boost graph.
- Testing boost bellman-ford functionality
Details can be found at [1] and PR at [2]
What do you plan on doing next week?
Implement the function to work with negative edges.
Refine function’s outputs and signature
Start working on the implementation of parallel Dijkstra algorithm(if time permits)
Are you blocked on anything?
No, I am not blocked.
THe wiki and repository can be found in [3] and [4] respectively.
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford#week-6-18-june—24-june
[2] https://github.com/pgRouting/pgrouting/pull/1049
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford
[4] https://github.com/pgRouting/pgrouting/tree/gsoc/bellmanford-one-to-one
Sourabh Garg
IIT BHU, India
