This is my report for week 7(June25-July 1).
What did you get done this week?
Clean and Working pgr_bellmanFord for positive edges [1]
Create function’s signature for allowing negative edge sql query [2]
Building graph and applying algorithm with negative edges [3]
Details and PR can be found at [4] and [5] respectively.
What do you plan on doing next week?
- Start Experimenting with parallel boost graph library, creating some sample examples.
- Implementing parallel functionality in pgRouting.
Are you blocked on anything?
No, I am not blocked currently.
The wiki and repository can be found in [4] and [6].
[1]. https://github.com/codeSG/pgrouting/issues/6
[2]. https://github.com/codeSG/pgrouting/issues/6
[3]. https://github.com/codeSG/pgrouting/issues/6
[4]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford
[5]. https://github.com/pgRouting/pgrouting/pull/1053
[6]. https://github.com/pgRouting/pgrouting/tree/gsoc/bellmanford-one-to-one
Sourabh Garg
