Hi All,
This is my report for Week 8 (July 2 to July 8).
What did you get done this week?
- Fix compile and documentation warnings.
- Updated documentation for pgr_bellmanFord function.
- Set up the environment for working with MPI and PBGL.
- Experimentation of parallel boost graph library.
Details of PR can be found at [1]&[2].
There are currently two branches on which I am working presently[3][4].
What do you plan on doing next week?
- Implement few more tests with parallel boost graph library.
- Implementing parallel_dijkstra functionality in pgRouting ( If time permits)
Currently, I am not blocked.
The project’s wiki can be found at [5].
[1]. https://github.com/pgRouting/pgrouting/pull/1060
[2]. https://github.com/pgRouting/pgrouting/pull/1061
[3]. https://github.com/pgRouting/pgrouting/tree/bellmanFord
[4]. https://github.com/pgRouting/pgrouting/tree/gsoc/parallel-dijkstra
[5]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford
Sourabh Garg
IIT BHU, India
