I did a little more work on this. I added a cmake/FindSphinx.cmake file and as I mentioned before add -DWITH_DOC=ON target.
Also we have the README.md should this get renamed to rst and get build built as part of the doc.
So my plan for the"doc" directory it to have one file there that would be our index.rst -> index.html and this file would have a project overview and an index to other docs like:
project - A more detailed project overview including PSC, source,
download links, listserv links, ...
users-guide - Detailed doc on each major function and helper functions
tutorial - List of tutorials and links (might be in subdirs)
gallery - Standardized description and link to apps using pgr
presentations - List of presentations and links (might be in subdirs)
developers - Developer standards, howtos
FAQ - FAQ document
... - other stuff as appropriate
Where each of these would be a subdirectory and would contain pages and or additional subdirs as needed.
But it still has some problems:
woodbri@maps:~/work/pgrouting$ cmake -H. -Bmybuild -DWITH_TSP=ON -DWITH_DD=ON -DWITH_DOC=ON
-- The C compiler identification is GNU 4.4.5
-- The CXX compiler identification is GNU 4.4.5
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/8.4/bin/postgres
-- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
-- Found PostgreSQL: /usr/include/postgresql/8.4/server, /usr/lib
-- Boost version: 1.42.0
Boost headers were found here: /usr/include
POSTGRESQL_VERSION_STRING is PostgreSQL 8.4.16
POSTGRESQL_VERSION is 8.4.16
Install directory for libraries is set to /usr/lib/postgresql/8.4/lib
Install directory for SQL files is set to /usr/share/pgrouting
-- Found Sphinx: /usr/bin/sphinx-build
Installation directory for libraries is set to /usr/lib/postgresql/8.4/lib and for SQL files is set to /usr/share/pgrouting
-- Found GAUL: /usr/local/lib/libgaul.so, /usr/local/lib/libgaul_util.so
-- Found CGAL: /usr/include, /usr/lib/libCGAL.so, /usr/lib/libboost_thread.so, /usr/lib/libgmp.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/woodbri/work/pgrouting/mybuild
woodbri@maps:~/work/pgrouting$ cd mybuild/
woodbri@maps:~/work/pgrouting/mybuild$ make
Scanning dependencies of target trsp
[ 6%] Building C object core/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
[ 12%] Building CXX object core/trsp/src/CMakeFiles/trsp.dir/trsp_core.cpp.o
[ 18%] Building CXX object core/trsp/src/CMakeFiles/trsp.dir/GraphDefinition.cpp.o
[ 18%] Built target trsp
Scanning dependencies of target astar
[ 25%] Building C object core/astar/src/CMakeFiles/astar.dir/astar.c.o
[ 31%] Building CXX object core/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
[ 31%] Built target astar
Scanning dependencies of target dijkstra
[ 37%] Building C object core/dijkstra/src/CMakeFiles/dijkstra.dir/dijkstra.c.o
[ 43%] Building CXX object core/dijkstra/src/CMakeFiles/dijkstra.dir/boost_wrapper.cpp.o
[ 43%] Built target dijkstra
Scanning dependencies of target shooting_star
[ 50%] Building C object core/shooting_star/src/CMakeFiles/shooting_star.dir/shooting_star.c.o
[ 56%] Building CXX object core/shooting_star/src/CMakeFiles/shooting_star.dir/shooting_star_boost_wrapper.cpp.o
[ 56%] Built target shooting_star
Scanning dependencies of target routing
Linking CXX shared library lib/librouting.so
[ 56%] Built target routing
Scanning dependencies of target my_project_docs
[ 62%] Building HTML documentation with Sphinx
Making output directory...
/home/woodbri/work/pgrouting/doc/README.rst:109: WARNING: image file not readable: build/trsp-test-image.png
/home/woodbri/work/pgrouting/doc/index.rst:11: (WARNING/2) toctree references unknown document u'...'
WARNING: static directory '/home/woodbri/work/pgrouting/mybuild/doc/_build/_static' does not exist
[ 62%] Built target my_project_docs
Scanning dependencies of target routing_tsp
[ 68%] Building C object core/tsp/src/CMakeFiles/routing_tsp.dir/tsp.c.o
[ 75%] Building CXX object core/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.cpp.o
Linking CXX shared library ../../../lib/librouting_tsp.so
[ 75%] Built target routing_tsp
Scanning dependencies of target routing_dd
[ 81%] Building C object core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.c.o
[ 87%] Building CXX object core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.cpp.o
[ 93%] Building CXX object core/driving_distance/src/CMakeFiles/routing_dd.dir/boost_drivedist.cpp.o
[100%] Building C object core/driving_distance/src/CMakeFiles/routing_dd.dir/drivedist.c.o
Linking CXX shared library ../../../lib/librouting_dd.so
[100%] Built target routing_dd
In the current CMakeLists.txt file I actually assemble the sql files during the cmake run and not during the make. This is probably wrong. It was not obvious to me how to change the cmake to that this process got move to the make process rather than the config process. I assume it involves creating a cmake script that gets run as a Makefile target.
Any thoughts on how to do this?
It would probably be a good idea when you guys have some time to review and make changes to the cmake stuff. I would like to see if we can break this up into a collection of callable modules the tackle the various configuration tasks and the make tasks.
-Steve
On 3/23/2013 4:37 PM, Stephen Woodbridge wrote:
Hi Daniel,
FAQ - FAQ document
-- Configuring done
-- Generating done
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
HI Steve,
I think something went totally wrong this night and I made you some extra work, that wasn’t necessary. Sorry for that.
Your comment made me wondering, because I had created this file and everything worked.
Then I realized that .gitignore had set all .cmake files to be ignored, also new ones added to the cmake directory.
Of course this is wrong and because of that my commit was not complete, missing the most important part.
Well, if we decide to use a build directory .gitignore could be empty actually.
I pushed the changes, so now everything should be at the right place.
Daniel
