Luis,
All these are good points.
It might also be possible for the client to cause things to leak on the server. For example, somethings are created on the server for the client and they persist for the duration of the the connection.
Another possibility, is that python might be running all the queries in the connection within a transaction, and this allocates memory on the server to handle a potential rollback.
You could try closing and opening the connection between requests to see if it is related to these.
If you know php, you could try rewriting your script into php (which I'm more familiar with) and see if your get the same behavior.
Or you could write all your queries to a text file, then run the text file as input to psql and see if the memory grows. If it does not then this indicates something weird with the python happening.
./mypython > myqueries.sql
psql mydatabase -f myqueries.sql &> myqueries.log
I'm not saying that the problem is not server side only that the valgrind logs do not indicate a problem specifically with pgrouting.
At this point we need to divide problem into smaller pieces like the above suggestion. If we can reproduce it without python, then we can eliminate that as the issue. If we can reproduce it with psql and text file of sql commands then it indicates something is likely leaking in pgrouting and we did not hit the right query in valgrind to reproduce it.
pgRouting does not do much/any? clean up on error conditions so this is possibly an error to look at.
-Steve
On 2/27/2015 3:23 AM, Luís de Sousa wrote:
Hi Steve, my comments go below.
On 26 February 2015 at 16:41, Stephen Woodbridge
<woodbri@swoodbridge.com> wrote:
Hi Luis,
I looked at the valgrind log and it is basically the same as a single query
and I do not see any leaks coming from pgrouting.
I think you should start looking at how you are using python.
https://www.google.com/?gws_rd=ssl#newwindow=1&q=psycopg2+memory+leak
I have no memory issues client side, even if the python code is minimal.
Also, looking at your code, you are computing random start and end node_ids
for the query:
1) are you sure you have all nodes from 1 to max+1?
Yes.
2) it is possible that if a query errors out that we might leak memory and
if this is the case you should attach a simple test case and valgrind log to
a bug report.
This is a possibility (e.g. network islands). I will follow this lead.
Also, in your python you are using fetchall() but you are never freeing the
results.
Again, this might not be conventional code, but the memory issue is on
the server.
Anyway, at this point I do not see a problem with pgrouting and I'm not
seeing this issue on any of my 12.04 systems.
At this stage I am also inclined to consider this an issue external to
pgRouting. However, the fact that you are able to run the script
without problems clearly points to the server side.
I will keep investigating this problem. If something further comes up
relevant to pgRouting I will report back.
Thank you and regards,
Luís
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
