This is just something I wanted to bring to your attention.
It seems that at revision:
Revision: f5ac454c40c3369d8a60ae45ee1a47e5bbd7997c
/develop
Branch new options were introduced to test-runner
Added options for -pgport and -clean to test-runner
Which broke testing on winnie because it caused the standard PostgreSQL
environment variable PGPORT to be ignored.
For building extensions and testing against a test instance, I've been in
the habit of just setting this
export PGPORT=105432
For example and prior to this change, this worked and the tests would run
against that port. After this change
Without the -pgport variable it now defaults to 5432 and ignores the PGPORT
variable.
I think its okay to keep the -pgport switch, but if PGPORT is set, it should
be respected and use that otherwise it deviates from the behavior of how
other PostgreSQL testing is done and liable to confuse a lot of package
maintainers.
Regina
http://www.postgis.us
http://postgis.net
