Hi All,
More TSP for today. In testing the example in the docs against the example data, I get what is to me a cryptic error:
SELECT * FROM pgr_tsp(‘SELECT id AS source_id, x, y FROM vertex_table’,‘2,7,11’,7);
ERROR: Error TSP fail to findEulerianPath, check your distance matrix is valid.
********** Error **********
SQL state: XX000
I get an entirely different error against my OSM data, but one error at a time… .
Best,
Steve
On 6/15/2013 2:44 PM, Stephen Mather wrote:
Hi All,
SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
vertex_table','2,7,11',7);
is valid.
This typically means there is something bad happening in the distance matrix that is getting passed to the TSP function. Hmmm.
I would start with can you run the test cases or do they fail on your system.
What OS system and versions of stuff are you running?
There TSP solution for 3 points is a triangle, it is a trivial case where the input is the output. I thought is tested for that case but maybe not.
BTW, I will be away on vacation without net access through June 25th, so I will not be much help until I get back.
-Steve
valid.
SQL state: XX000
a time... .
Best,
Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
