Ok, definitely some failures:
$stats = {
'src/apsp_johnson/test/test.conf' => [
'comment' => 'APSP Johnson test for any versions.',
'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
'src/apsp_warshall/test/test.conf' => [
'comment' => 'APSP Warshall test for any versions.',
'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
'src/astar/test/test.conf' => [
'comment' => 'astar test for any versions.',
'src/astar/test/spas-any-00.test' => 'Passed',
'src/astar/test/spas-any-01.test' => 'Passed'
'src/bd_astar/test/test.conf' => [
'comment' => 'Bi-directional AStar test for any versions.',
'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
'src/bd_dijkstra/test/test.conf' => [
'comment' => 'Bi-directional Dijkstra test for any versions.',
'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
'src/common/test/test.conf' => [
'comment' => 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any versions.',
'src/common/test/common-any-01.test' => 'FAILED: 1,3d0
< psql:src/common/test/common-any-01.test:1: NOTICE: table "vertices_tmp" does not exist, skipping
< CONTEXT: SQL statement "DROP TABLE IF EXISTS vertices_tmp"
< PL/pgSQL function pgr_createtopology(character varying,double precision,character varying,character varying) line 48 at SQL statement
6c3
< PL/pgSQL function pgr_createtopology(character varying,double precision,character varying,character varying) line 49 at SQL statement
> PL/pgSQL function "pgr_createtopology" line 49 at SQL statement',
'src/common/test/common-any-02.test' => 'Passed',
'src/common/test/common-any-03.test' => 'Passed',
'src/common/test/common-any-04.test' => 'FAILED: 3c3
< PL/pgSQL function pgr_nodenetwork(text,text,text,text,double precision) line 23 at SQL statement
> PL/pgSQL function "pgr_nodenetwork" line 23 at SQL statement
9c9
< PL/pgSQL function pgr_nodenetwork(text,text,text,text,double precision) line 58 at SQL statement
> PL/pgSQL function "pgr_nodenetwork" line 58 at SQL statement
12c12
< PL/pgSQL function pgr_nodenetwork(text,text,text,text,double precision) line 71 at EXECUTE statement
> PL/pgSQL function "pgr_nodenetwork" line 71 at EXECUTE statement
62c62
'src/common/test/versionless-any-01.test' => 'Passed'
'src/dijkstra/test/test.conf' => [
'comment' => 'Dijkstra test for any versions.',
'src/dijkstra/test/spd-any-00.test' => 'Passed',
'src/dijkstra/test/spd-any-01.test' => 'Passed',
'src/dijkstra/test/spd-any-02.test' => 'Passed',
'src/dijkstra/test/spd-any-03.test' => 'Passed'
'src/driving_distance/test/test.conf' => [
'comment' => 'Driving Distance test for any versions.',
'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
'src/kdijkstra/test/test.conf' => [
'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed'
'src/ksp/test/test.conf' => [
'comment' => 'KSP test for any versions.',
'src/ksp/test/ksp-any-01.test' => 'Passed',
'src/ksp/test/ksp-any-02.test' => 'Passed'
'src/trsp/test/test.conf' => [
'comment' => 'TRSP test for any versions.',
'src/trsp/test/trsp-any-00.test' => 'Passed',
'src/trsp/test/trsp-any-01.test' => 'Passed',
'src/trsp/test/trsp-any-02.test' => 'Passed',
'src/trsp/test/trsp-any-03.test' => 'Passed'
'src/tsp/test/test.conf' => [
'comment' => 'TSP test for any versions.',
'src/tsp/test/tsp-any-00.test' => 'Passed',
'src/tsp/test/tsp-any-01.test' => 'Passed',
'src/tsp/test/tsp-any-02.test' => 'Passed'
'z_crash' => 0,
'z_fail' => 2,
'z_pass' => 35
On 06/15/2013 05:09 PM, Stephen Mather wrote:
Hmm. I did a clone w -b develop, so I never did a checkout of the repository after the clone. Also didn't configure the docs dependencies. Otherwise, it looks the same. About to rerun...
Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
If you are in the pgrouting git source tree like:
git clone git://github.com/pgRouting/pgrouting.git
cd pgrouting
git checkout develop
cat tools/doit # this is my build script, it may not work for you
tools/doit
tools/test-runner.pl # this will run all the tests
The test script make a test database, loads the data and runs the tests.
If you look in src/tsp/test
CMakeLists.txt tsp-any-00.rest tsp-any-01.test tsp-any-03.rest
test.conf tsp-any-00.test tsp-any-02.rest tsp-any-03.test
tsp-any-00.data tsp-any-01.rest tsp-any-02.test
createdb runtests
psql runtests -c "create extension postgis"
psql runtests -c "create extension pgrouting"
psql runtests -f src/tsp/test/tsp-any-00.data # load some data
psql runtests -A -t -f src/tsp/test/tsp-any-00.test
psql runtests -A -t -f src/tsp/test/tsp-any-01.test
psql runtests -A -t -f src/tsp/test/tsp-any-02.test
psql runtests -A -t -f src/tsp/test/tsp-any-03.test
The output of each command should be the same as *.rest file.
-Steve
On 6/15/2013 4:39 PM, Stephen Mather wrote:
Ubuntu 12.04LTS
Postgis 2.0.1 r9979
GEOS 3.3.8-capi-1.7.8
proj 4.8.0
gdal 1.9.2
Libxml 2.7.8
pgr_version ()
2.0.0-Dev
V2.0.0-alpha,31,15ac46d,feature-travis,1.46.1
When I run tests, it fails on every test w function not found. Do I need to prep the database in any way to run the tests?
Stephen Mather <stephen@smathermather.com> wrote:
I have not tried tests yet but have have run astar and djikstra w no problem. When does vacation start... I can run tests asap... ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
On 6/15/2013 2:44 PM, Stephen Mather wrote:
Hi All,
More TSP for today. In testing the example in the docs against the
example data, I get what is to me a cryptic error:
SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
vertex_table','2,7,11',7);
ERROR: Error TSP fail to findEulerianPath, check your distance matrix
is valid.
This typically means there is something bad happening in the distance
matrix that is getting passed to the TSP function. Hmmm.
I would start with can you run the test cases or do they fail on your
system.
What OS system and versions of stuff are you running?
There TSP solution for 3 points is a triangle, it is a trivial case
where the input is the output. I thought is tested for that case but
maybe not.
BTW, I will be away on vacation without net access through June 25th, so
I will not be much help until I get back.
-Steve
********** Error **********
ERROR: Error TSP fail to findEulerianPath, check your distance matrix is
valid.
SQL state: XX000
I get an entirely different error against my OSM data, but one error at
a time... .
Best,
Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
