Since I rarely throw anything out, I was about to find the TRSP testmain.cpp code. This might be used as an example of how to test the core algorithm outside of postgresql. Oh and another benefit of this is that you can run the code under valgrind to identify memory leaks and potential array indexing issues.
At some point I will add these to my git branch so these and some of the other test files are available.
Obviously, you would need to modify this for your code but I can see each algorithm as having a similar tool to load and run files for testing.
-Steve
$ cat testmain.cpp
#include "GraphDefinition.h"
#include "utils.h"
#include <string.h>
std::vector<edge_t> vecEdges;
std::vector<PDVI> ruleTable;
int main()
edge_t *edges;
int edge_count;
char buff[1024];
std::string edgeFile = "edges-b1.txt";
std::string ruleFile = "rules-b1.txt";
freopen(edgeFile.c_str(), "rt", stdin);
edge_count = 0;
vecEdges.clear();
while(gets(buff))
if(strlen(buff) == 0)
break;
edge_count++;
StringTokenizer token;
token.parse(buff, ",");
std::vector<std::string> vecToken;
token.getTokens(vecToken);
if(vecToken.size() < 5)
fprintf(stderr, "Error in %d edge\n", edge_count);
edge_t tempEdge;
tempEdge.id = atoi(vecToken[0].c_str());
tempEdge.source = atoi(vecToken[1].c_str());
tempEdge.target = atoi(vecToken[2].c_str());
tempEdge.cost = atof(vecToken[3].c_str());
tempEdge.reverse_cost = atof(vecToken[4].c_str());
vecEdges.push_back(tempEdge);
edges = new edge_t[edge_count];
int i;
for(i = 0; i < edge_count; i++)
edges[i] = vecEdges[i];
freopen(ruleFile.c_str(), "rt", stdin);
ruleTable.clear();
while(gets(buff))
break;
int totalTokens = vecToken.size();
std::vector<int> seq;
seq.clear();
for(i = 1; i < totalTokens; i++)
seq.push_back(atoi(vecToken[i].c_str()));
ruleTable.push_back(make_pair(atof(vecToken[0].c_str()), seq));
path_element_t *path;
char *err_msg;
int path_count;
GraphDefinition gdef;
int res = gdef.my_dijkstra(edges, edge_count, 32966, 33353, &path, &path_count, &err_msg, ruleTable);
freopen("result-nt.txt", "wt", stdout);
if(res < 0)
printf("%s\n", err_msg);
else
for(i = 0; i < path_count; i++)
printf("%d\t|%d\t|%.6lf\n", path[i].vertex_id, path[i].edge_id, path[i].cost);
free(path);
delete edges;
return 0;
Here is an example input file:
$ cat edge2.txt
1,1,6,1,1
2,2,3,1,1
3,3,4,1,1
4,4,5,1,1
5,5,6,1,1
6,2,7,1,1
7,3,8,1,1
8,4,9,1,1
9,5,10,1,1
10,6,11,1,1
11,7,8,1,1
12,8,9,1,1
13,9,10,1,1
14,10,11,1,1
15,7,12,1,1
16,8,13,1,1
17,9,14,1,1
18,10,15,1,1
19,11,16,1,1
20,12,13,1,1
21,13,14,1,1
22,14,15,1,1
23,15,16,1,1
24,12,17,1,1
25,13,18,1,1
26,14,19,1,1
27,15,20,1,1
28,16,21,1,1
29,17,18,1,1
30,18,19,1,1
31,19,20,1,1
32,20,21,1,1
33,17,22,1,1
34,18,23,1,1
35,19,24,1,1
36,20,25,1,1
37,21,26,1,1
38,22,23,1,1
39,23,24,1,1
40,24,25,1,1
41,25,26,1,1
42,22,27,1,1
And a sample restrictions table:
$ cat rules2.txt
1.1,5,1
1.1,14,10
1.1,23,19
1.1,32,28
1.1,13,9
1.1,5,9
1.1,22,18
1.1,14,18
1.1,31,27
1.1,23,27
1.1,40,36
1.1,32,36
1.1,12,8
1.1,4,8
1.1,21,17
1.1,13,17
1.1,30,26
1.1,22,26
1.1,39,35
1.1,31,35
1.1,11,7
1.1,3,7
1.1,20,16
1.1,12,16
1.1,29,25
1.1,21,25
1.1,38,34
1.1,30,34
1.1,38,42
1.1,29,33
1.1,20,24
1.1,11,15
1.1,10,5
1.1,9,4
1.1,8,3
1.1,7,2
1.1,9,14
1.1,19,14
1.1,8,13
1.1,18,13
1.1,7,12
1.1,17,12
1.1,6,11
1.1,16,11
1.1,18,23
1.1,28,23
1.1,17,22
1.1,27,22
1.1,16,21
1.1,26,21
1.1,15,20
1.1,25,20
1.1,27,32
1.1,37,32
1.1,26,31
1.1,36,31
1.1,25,30
1.1,35,30
1.1,24,29
1.1,34,29
1.1,36,41
1.1,35,40
1.1,34,39
1.1,33,38
