My schedule is for the next 2 wks will be focused on some contract work I have to deliver So I'm not sure how much time I will have to tackle pgRouting issues.
I think I can work in looking at the new TSP issues for that starts. My next major pgrouting task is to look at them memory issues that are causing crashes and std::bad_alloc issues. I'm not looking forward to this task because the problems seems to be intermitent and the fact that is works in one setup does not mean that you have solved the problem. I also think this is related to postgresql palloc usage and subtle issues related to that.
My schedule is for the next 2 wks will be focused on some contract work I have to deliver So I’m not sure how much time I will have to tackle pgRouting issues.
I think I can work in looking at the new TSP issues for that starts. My next major pgrouting task is to look at them memory issues that are causing crashes and std::bad_alloc issues. I’m not looking forward to this task because the problems seems to be intermitent and the fact that is works in one setup does not mean that you have solved the problem. I also think this is related to postgresql palloc usage and subtle issues related to that.
I will try to fix Windows/Mac related critical issues at next week.
2013/6/27 Stephen Woodbridge <woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>>
Hi All,
Dave P. - thanks for the TSP problem reports.
Nagase-san - thank you for the crash reports.
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org <mailto:pgrouting-dev@lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Ko Nagase (sanak)
Georepublic Japan
mail: geosanak@gmail.com <mailto:geosanak@gmail.com>
nagase@georepublic.co.jp <mailto:nagase@georepublic.co.jp>
Sorry, I just started to check new pgRouting 2.0 and its issues,
but, if you use Linux(Ubuntu .etc), it seems that there is no reported issue about ksp memory problems.
All I was trying to say was that during my development of the KSP wrapper I had some memory problems, I resolved them. Before submitting the code. As far as I am aware there are no memory issues with the ksp code.
I was wondering what the memory problems were with the tsp code.
regards
Dave.
Hi Dave,
So, in that case, could you create a new issue?
2013/6/27 Dave Potts <dave.potts@pinan.co.uk <mailto:dave.potts@pinan.co.uk>>
On 27/06/13 07:07, sanak wrote:
hi
Is there a bug tag with the memory problems ?
I had some rather strange experiences with memory issues when I
was writing the ksp wrapper.
Another gotcha on the web site for getting the source version
refer to 1.0 release and not the development one.
Dave.
Hi Stephen,
Thanks for comment.
Hi All,
-Steve
-- Ko Nagase (sanak)
Georepublic Japan
regards
Dave.
Hi Dave,
[pgrouting-dev@lists.osgeo.org](mailto:pgrouting-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/pgrouting-dev](http://lists.osgeo.org/mailman/listinfo/pgrouting-dev)
If you find specific crashes or issues you should create a new ticket with all the appropriate details on how to reproduce it and in the body of that ticket include '#141' so they are linked.
-Steve
On 6/26/2013 11:06 PM, Stephen Woodbridge wrote:
Hi All,
pgRouting issues.
related to that.
I just checked in a few changes related to TSP issues.
1. fixed the order reporting when an end node is specified
2. added checks if less than 4 locations are requested in tsp and report error
3. fixed some other minor bugs I found while review the code
that really needs to be fixed, but I'm not sure how this was intended to work in the first place before I converted it to the new code. I added a bunch of questions to the the ticket. Some feedback would be appreciated.
-Steve
Hi All,
pgRouting issues.
related to that.
