On 15/08/13 02:21, Stephen Woodbridge wrote:
On 8/14/2013 6:19 PM, Dave Potts wrote:
I am trying to write some code in c++
Its suggested that I should pfree/pmalloc to delete and free memory.
Problem is that when I use them, I get an error from the loader
select pgr_sql_check_tsp('select * from edge4');
ERROR: could not load library
"/usr/lib/postgresql/9.1/lib/librouting_tsp.so":
/usr/lib/postgresql/9.1/lib/librouting_tsp.so: undefined symbol:
_Z18MemoryContextAllocP17MemoryContextDatam
atsp=#
It looks like a name mangling issue
I tried inserting extern "C" statments around the postgres include files
(palloc.h) in my code because I discovered that, postgres source does
not do this, results same issue.
I noticed that ./src/apsp_warshall/src/apsp_boost_wrapper.cpp, has an
instance of pfree commented out, is there a reasons for this?
Does anybody known
1. Is it possible to use pfree/palloc in a potgres cpp file?
I don't recommend doing this because this memory is allocated in various contexts that are not always obvious and if the context goes out of scope the all the memory allocated in that context is no longer valid. Also memory that is palloc does not need to be pfree'd because it gets cleaned when the context is done with.
2. Can I use new/malloc/delete etc instead of pfree/palloc
Yes this is the way to go, there are no problems with this. One thing I will comment on with C++ is that if you are using std::vector, then do not push back large struct objects, instead create them with new() and push a pointer onto std::vector then later, delete all the objects based on their points on the std::vector. We had to change a lot of code to prevent std::bad_alloc when we tried to push the objects rather than their pointers
-Steve
hi Steve,
The problem is with the 'name managler', to ensure that enclosure, access to scope rules etc is done 'correctly' all symbols that would be could be accessed from cpp module have their names mangled, ie a call to pfree is rewritten to _Z18MemoryContextAllocP17MemoryContextDatam. Inserting the code 'extern C {' should stop this happening. I tried it around all of the included postgres files, again it did'nt work as expected.
My solution is to cheat! I have a driver function bar.c which calls some code in foo.cpp, in bar.c I added the following routines
void * getMem(size_t request ){
return palloc(request);
void releaseMem(void *mem ){
pfree (mem);
in foo.cpp, I defined them as
extern "C" {
void * getMem(size_t request );
void releaseMem(void *mem );
My code links correctly, with no errors. The problem is really with the Postgres header files, they should be desgined to called from cpp instead of just c. Not nice but a minor hack that seems to resolve the current issue.
I take the point about std::vector,std::bad_alloc and their friends. I will define my data structures in such a way that they will not be automatically allocated or extended for me by the helpful C++ run time system. This should avoid the issue.
Dave.
regards
Dave.
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
