Looks great as long as it returns all the information required for debugging pg route that can not be got from elsewhere. It returns information about which version of the pgr code has been used, but does it include the version information for the dependency of libraries used to build pgr?
POSTGIS="2.0.0 r9605" GEOS="3.3.8-CAPI-1.7.82 PROJ="Rel.4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, release 2012/10/08" LIBJSON="UNKNOWN" RASTER
With this information I would known everything required to build the right version of postgis, does'nt pgr include some support from some 3rd party libraries?
On Wed, May 29, 2013 at 1:17 PM, Daniel Kastl <daniel@georepublic.de <mailto:daniel@georepublic.de>> wrote:
On Wed, May 29, 2013 at 12:53 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 5/28/2013 11:40 PM, Daniel Kastl wrote:
On Wed, May 29, 2013 at 12:18 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.com>>> wrote:
On 5/28/2013 10:14 PM, Daniel Kastl wrote:
What about just one "pgr_version()" function?
I don't get the use case where we need two of them ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
I think "pgr_version()" should then return the
"full" version.
I'm fine with have to two functions.
pgr_full_version() - this would be the full string
with everything
pgr_version() - this should match version of
extension like:
2.0.0-dev in
pgrouting--2.0.0-dev.sql
The full version string is what we want for bug reporting.
The version is what you might want to use in an
application to
construct if clauses based on features available in
this or that
version of the software.
What about
pgr_version() -> should match version of extension
pgr_version("full") -> full string with everything (could
be also "debug")
I know this is not really important discussion, but we did
so well in
decreasing the number of functions and then we're having
multiple ones
for just getting the version information ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Also I had to add two pages to the function reference somehow.
I still like the idea to return a record, because someone
could pick
what is important if used for an application, like:
SELECT * FROM pgr_version();
version | tag | build | hash | branch
2.0.0-dev | v2.0dev | 271 | g6eeef9b | sew-devel-2_0
So one could get the version with SELECT version FROM
pgr_version() in
case they really use it for some application for example;
This would require defining a new TYPE, I suppose I we could
return text then you could use array_to_string() to concat
them with hyphens.
I don't like the idea of passing arguments to get different
strings, because I have not seen it on any other apps.
Me neither. I would prefer to query for attributes as well.
I would just have leave it as two functions and put them both
on one doc page. Or if you want it parsed return a text
array. I'm happy to make the changes that is trivial.
Do you really need to define new types to return a table?
I just did it like this in another function variant:
https://github.com/pgRouting/pgrouting/blob/sew-devel-2_0/src/common/sql/pgrouting_network_check.sql
I didn't have to create a type for that.
I tried this and it works pretty well:
CREATE OR REPLACE FUNCTION public.pgr_version()
RETURNS TABLE(
"version" varchar,
tag varchar,
build varchar,
hash varchar,
branch varchar
) AS
$BODY$
DECLARE
BEGIN
--return '2.0.0-dev v2.0dev-285-g101f36a sew-devel-2_0';
RETURN QUERY SELECT '2.0.0-dev'::varchar AS version,'v2.0dev'::varchar AS tag,
'285'::varchar AS build, 'g101f36a'::varchar AS hash,
'sew-devel-2_0'::varchar AS branch;
END;
$BODY$
LANGUAGE plpgsql IMMUTABLE
COST 100;
You can run either with "SELECT * FROM pgr_version()"
psql -U postgres -d doc -c "SELECT * FROM public.pgr_version()"
2.0.0-dev | v2.0dev | 285 | g101f36a | sew-devel-2_0
(1 row)
Or just "SELECT pgr_version()"
psql -U postgres -d doc -c "SELECT public.pgr_version()"
pgr_version
(2.0.0-dev,v2.0dev,285,g101f36a,sew-devel-2_0)
(1 row)
I think this should satisfy everyone. No? ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
