Weird. Second time around the bdstar-any.test passed (so maybe that's some
sort of memory issue that shows up on some runs and not others)
The utilities test looks harmless (and I think I saw a note in a ticket you
updated that to match) so I can probably ignore that one.
Regina
-----Original Message-----
[mailto:pgrouting-dev-bounces@lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Saturday, December 20, 2014 10:55 PM
To: 'pgRouting developers mailing list'
Subject: Re: [pgrouting-dev] Versioning questions issue with PostgreSQL 9.4
Steve,
Thanks for the input. I was thinking the same thing myself. Unfortunately
I've run into a bit of a problem. The regression tests past fine againts
develop for PostgreSQL 9.4, but I have two failures if I build against
tagged 2.0.0
Were there patches introduced to support PostgreSQL 9.4 in develop?
Here are failures against PostgreSQL 9.4 64-bit (the job failed before it
built the 32-bit version so not sure if there is an issue there as well)
$stats = {
'doc/test/test.conf' => [
'comment' => 'documentation SQL tests
for any versions.',
'doc/test/alphashape-any.test' =>
'Passed',
'doc/test/analyzeGraph-any.test' =>
'Passed',
'doc/test/analyzeOneway-any.test' =>
'Passed',
'doc/test/apspJohnson-any.test' =>
'Passed',
'doc/test/apspWarshall-any.test' =>
'Passed',
'doc/test/astar-any.test' =>
'Passed',
'doc/test/bdDijkstra-any.test' =>
'Passed',
'doc/test/bdstar-any.test' =>
'FAILED: 1,5c1
< 0|4|3|0
< 1|3|5|1
< 2|6|11|1
< 3|11|12|0
< 4|10|-1|0
ERROR: Error computing path: Path Not Found',
'doc/test/createTopology-any.test' =>
'Passed',
'doc/test/createVertTab-any.test' =>
'Passed',
'doc/test/dijkstra-any.test' =>
'Passed',
'doc/test/drivingDistance-any.test'
=> 'Passed',
'doc/test/kdijkstra-any.test' =>
'Passed',
'doc/test/nodeNetwork-any.test' =>
'Passed',
'doc/test/pointsAsPolygon-any.test'
=> 'Passed',
'doc/test/sampledata.test' =>
'Passed',
'doc/test/trsp-any.test' => 'Passed',
'doc/test/tsp-any.test' => 'Passed',
'doc/test/utilities-any.test' =>
'FAILED: 1c1
< 2.0.0|v2.0.0
2.0.0|pgrouting-2.0.0'
Regina
On 12/20/2014 12:24 PM, Paragon Corporation wrote:
1) What is develop_2_0_1
I don't recall anywhere being listed a 2.0.1 release. Or was that
never released.
develop_2_0_1 was create to for bug fixes to the the 2.0.0 release, but I'm
not sure that it is different from 2.0.0 (ie: there has not been anything
done on it, but I have not diff'ed it to be sure).
develop* branches are where we work on stuff before it is released.
2) On a slightly more embarassing note, I just built the PostGIS 2.1.5
/ pgRouting bundle package for PostgreSQL 9.4 windows 32 and 64-bit
and
pushed
to stackbuilder already (and I forgot to specify tag 2.0.0 during
build (since I just wanted to build for 9.4 and my tagged build job
builds for all versions) So I ended up with the latest develop branch
(which annoyingly enough says its 2.0.0 and pgrouting 2.0.0 for tag -
select * from pgr_version();;
version | tag | build | hash | branch | boost
2.0.0 | pgrouting-2.0.0 | 78 | abde224 | develop | 1.53.0
(1 row)
Vs. pgRouting (currently shipped)
2.0.0 | pgrouting-2.0.0 | 0 | d6ed2cb | master | 1.53.0
though
I probably should have been alerted of this when I saw an extra dll:
librouting_vrp.dll
Again the develop branch is where misc. pull requests and fixes have been
going which will eventually become 2.1.0 release, but we have not started a
concerted effort on developing this release yet.
I think the librouting_vrp stuff is part of one or more of the GSoC projects
that were VRP related.
My biggest concern with publishing the develop branch is that it has had
little or no effort put into it. This includes limited or no testing, no
documentation, etc.
So my question is how do people feel about this
A) Should I pull the release I just did and package with the tagged
pgRouting 2.0.0
Or
B) Just leave things as they are and live with the fact that
PostgreSQL
9.4
has a newer pgRouting. I'm more or less okay with this since PostGIS
2.1.5
pgRouting bundle will be the first for this version of PostgreSQL.
This I guess would be fine if most of the other changes are bug fixes,
slight enhancements and also if no functions were removed in the dlls
or function api changes since pgRouting 2.0.0 was released.
I think the safe thing to do it pull the package and build and push the
released 2.0.0 package if the is possible.
My main concern here is that since some people might be doing a
pg_upgrade from say 9.3 to 9.4 their upgrade would fail if they had
installed
in 9.3 and the 9.4 binaries don't have all the functions that were in
2.0.0
accounted for. Having more is not an issue.
Which brings me to related sub question 2:
If I go with B, and since I haven't built PostGIS 2.1.5/pgRouting
bundle
for
the other PostgreSQL versions yet should I stick with the tagged
v2.0.0 or ship with the same that I built with 9.4?
My gut feeling is to stick with 2.0.0 since I prefer a tagged build
over
an
untagged one, but then again I also hate my packages being slightly
different.
Thoughts?
I think we should stick with the tagged 2.0.0 packages so everyone is
running the same stuff. I know its more work but I really think it is the
right thing to do.
Thank you for all your work on behalf of the whole pgRouting community.
It is really appreciated.
All the best Season's Greetings,
-Steve
Regina
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
