The page http://docs.pgrouting.org/dev/doc/src/installation/index.html#build-from-source, lists 5 different branches, if I want to do some development work, which one should I use?
Dave.
Dave.
On Tue, Aug 27, 2013 at 4:06 AM, Dave Potts <dave.potts@pinan.co.uk> wrote:
The page http://docs.pgrouting.org/dev/**doc/src/installation/index.**
html#build-from-source<http://docs.pgrouting.org/dev/doc/src/installation/index.html#build-from-source>,
one should I use?
Hi Dave,
These are not different branches but tags, that can be downloaded.
If you want to develop, then you best clone the Git repository and use
branch "develop". There is only one of this name.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Agreed all development going forward will happen in the develop branch and at stable points this will get merged back into master. Think of master as where we drop stable releases, it is currently at something like 1.05+ and when 2.0 gets released, it will get merged into master to update that to the release. Otherwise nothing should be getting done in master. all the releases are tags in the develop branch to mark significant states in the process.
-Steve
<mailto:dave.potts@pinan.co.uk>> wrote:The page
http://docs.pgrouting.org/dev/__doc/src/installation/index.__html#build-from-source
which one should I use?Hi Dave,
branch "develop". There is only one of this name.Daniel
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>_______________________________________________
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
