Hello everyone
I have a query which i use to find a route between two points . Even though the route is displayed good on the map the order i get from pgrouting is wrong the query is this one
SELECT rt.gid, ST_AsGeoJSON(rt.the_geom) AS geojson,
length(ST_transform(rt.the_geom,3785))as meters,x1,x2,y1,y2,name, ways.gid
FROM ways,
(SELECT gid, the_geom
FROM dijkstra_sp_delta(
'ways',
714,
4807,
0.1)
) as rt
WHERE ways.gid=rt.gid;
do you know any way to take the segments of the route in right order ?
Thanks in advance
