Hi All,
The package management for Ubuntu 12.04 isn’t working for me (see earlier message about this), so I decided I’m an adequate keyboard cowboy to build from source, but alas, no such luck.
steve@lion:~/Documents/github/pgrouting$ mkdir build
steve@lion:~/Documents/github/pgrouting$ cd build/
steve@lion:~/Documents/github/pgrouting/build$ cmake -DWITH_DD=ON …
– The C compiler identification is GNU 4.6.3
– The CXX compiler identification is GNU 4.6.3
– Check for working C compiler: /usr/bin/gcc
– Check for working C compiler: /usr/bin/gcc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– PGROUTING_GIT_TAG: pgrouting-2.0.0
– PGROUTING_GIT_BUILD: 0
– PGROUTING_GIT_HASH: d6ed2cb
– PGROUTING_GIT_BRANCH: master
– PGROUTING_VERSION_REVISION_NAME: d6ed2cb master
– PGROUTING_VERSION_REVISION_HASH: d6ed2cb
– UNIX=1
– WIN32=
– POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
– POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
– POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.3/server
– POSTGRESQL_LIBRARIES: /usr/lib
– Boost version: 1.55.0
– Boost headers were found here: /usr/local/include
– POSTGRESQL_VERSION_STRING is PostgreSQL 9.3.1
– POSTGRESQL_VERSION is 9.3.1
– PGSQL_VERSION is 93
– Install directory for libraries is set to /usr/lib/postgresql/9.3/lib
– Contrib directory for SQL files is set to /usr/share/postgresql/9.3/contrib/pgrouting-2.0
– Extension directory for SQL files is set to /usr/share/postgresql/9.3/extension
– Found the following Boost libraries:
– thread
– thread
– system
– CGAL_INCLUDE_DIR=/usr/local/include
– CGAL_LIBRARIES=/usr/local/lib/libCGAL.so
– BOOST_THREAD_LIBRARIES=/usr/local/lib/libboost_thread.so;pthread;/usr/local/lib/libboost_thread.so;pthread;/usr/local/lib/libboost_system.so
– GMP_LIBRARIES=/usr/lib/x86_64-linux-gnu/libgmp.so
– Found CGAL: /usr/local/include, /usr/local/lib/libCGAL.so, /usr/local/lib/libboost_thread.so;pthread;/usr/local/lib/libboost_thread.so;pthread;/usr/local/lib/libboost_system.so, /usr/lib/x86_64-linux-gnu/libgmp.so
– Configuring done
– Generating done
– Build files have been written to: /home/smathermather/Documents/github/pgrouting/build
steve@lion:~/Documents/github/pgrouting/build$ make
Scanning dependencies of target trsp
[ 2%] Building C object src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
[ 5%] Building CXX object src/trsp/src/CMakeFiles/trsp.dir/trsp_core.cpp.o
[ 8%] Building CXX object src/trsp/src/CMakeFiles/trsp.dir/GraphDefinition.cpp.o
[ 8%] Built target trsp
Scanning dependencies of target astar
[ 11%] Building C object src/astar/src/CMakeFiles/astar.dir/astar.c.o
[ 14%] Building CXX object src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
[ 14%] Built target astar
Scanning dependencies of target dijkstra
[ 17%] Building C object src/dijkstra/src/CMakeFiles/dijkstra.dir/dijkstra.c.o
[ 20%] Building CXX object src/dijkstra/src/CMakeFiles/dijkstra.dir/boost_wrapper.cpp.o
[ 20%] Built target dijkstra
Scanning dependencies of target kdijkstra
[ 22%] Building CXX object src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o
[ 25%] Building C object src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_sp.c.o
[ 25%] Built target kdijkstra
Scanning dependencies of target apsp_johnson
[ 28%] Building C object src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson.c.o
[ 31%] Building CXX object src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson_boost_wrapper.cpp.o
[ 31%] Built target apsp_johnson
Scanning dependencies of target apsp_warshall
[ 34%] Building C object src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp.c.o
[ 37%] Building CXX object src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp_boost_wrapper.cpp.o
[ 37%] Built target apsp_warshall
Scanning dependencies of target routing
Linking CXX shared library lib/librouting.so
[ 37%] Built target routing
Scanning dependencies of target bd_dijkstra
[ 40%] Building C object src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp.c.o
[ 42%] Building CXX object src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp_core.cpp.o
[ 45%] Building CXX object src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/BiDirDijkstra.cpp.o
[ 45%] Built target bd_dijkstra
Scanning dependencies of target bd_astar
[ 48%] Building C object src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar.c.o
[ 51%] Building CXX object src/bd_astar/src/CMakeFiles/bd_astar.dir/MinHeap.cpp.o
[ 54%] Building CXX object src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar_core.cpp.o
[ 57%] Building CXX object src/bd_astar/src/CMakeFiles/bd_astar.dir/BiDirAStar.cpp.o
[ 57%] Built target bd_astar
Scanning dependencies of target routing_bd
Linking CXX shared library lib/librouting_bd.so
[ 57%] Built target routing_bd
Scanning dependencies of target routing_tsp
[ 60%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsp2.c.o
[ 62%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.o
Linking C shared library …/…/…/lib/librouting_tsp.so
[ 62%] Built target routing_tsp
Scanning dependencies of target routing_ksp
[ 65%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/BaseGraph.cpp.o
[ 68%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/BasePath.cpp.o
[ 71%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/DijkstraShortestPathAlg.cpp.o
[ 74%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/Graph.cpp.o
[ 77%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/HeaderTest.cpp.o
[ 80%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/YenTopKShortestPathsAlg.cpp.o
[ 82%] Building C object src/ksp/src/CMakeFiles/routing_ksp.dir/ksp.c.o
[ 85%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/KSPDriver.cpp.o
[ 88%] Building CXX object src/ksp/src/CMakeFiles/routing_ksp.dir/KSPGraph.cpp.o
Linking CXX shared library …/…/…/lib/librouting_ksp.so
[ 88%] Built target routing_ksp
Scanning dependencies of target routing_dd
[ 91%] Building C object src/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.c.o
[ 94%] Building CXX object src/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.cpp.o
[ 97%] Building CXX object src/driving_distance/src/CMakeFiles/routing_dd.dir/boost_drivedist.cpp.o
[100%] Building C object src/driving_distance/src/CMakeFiles/routing_dd.dir/drivedist.c.o
Linking CXX shared library …/…/…/lib/librouting_dd.so
[100%] Built target routing_dd
steve@lion:~/Documents/github/pgrouting/build$ sudo make install
Install the project…
– Install configuration: “”
– Installing: /usr/lib/postgresql/9.3/lib/librouting_bd.so
– Installing: /usr/lib/postgresql/9.3/lib/librouting.so
– Installing: /usr/share/postgresql/9.3/extension/pgrouting–2.0.0.sql
– Installing: /usr/share/postgresql/9.3/extension/pgrouting.control
– Installing: /usr/share/postgresql/9.3/extension/pgrouting_legacy.sql
– Installing: /usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting.sql
– Installing: /usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting.control
– Installing: /usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting_legacy.sql
– Installing: /usr/share/postgresql/9.3/extension/pgrouting_dd_legacy.sql
– Installing: /usr/share/postgresql/9.3/contrib/pgrouting-2.0/pgrouting_dd_legacy.sql
– Installing: /usr/lib/postgresql/9.3/lib/librouting_tsp.so
– Installing: /usr/lib/postgresql/9.3/lib/librouting_ksp.so
– Installing: /usr/lib/postgresql/9.3/lib/librouting_dd.so
– Removed runtime path from “/usr/lib/postgresql/9.3/lib/librouting_dd.so”
Now I create extension:
CREATE EXTENSION pgrouting;
And get the following error (naturally, since librouting_dd is being removed here at the end…):
ERROR: could not load library “/usr/lib/postgresql/9.3/lib/librouting_dd.so”: libCGAL.so.10: cannot open shared object file: No such file or directory
********** Error **********
SQL state: 58P01
Any idea what I’m doing wrong?
Best
Steve
