I am trying to add a route to a webserver with pmapper and mapserver but i can´t.
I tried like that:
LAYER
NAME "rota"
STATUS DEFAULT
TYPE LINE
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTION "user=pedro password=********** dbname=test host=localhost options='-c client_encoding=LATIN1'"
DATA "the_geom from
(SELECT id, the_geom
FROM arcos
JOIN
(SELECT * FROM shortest_path('
SELECT id2 as id,
source::int4 AS source,
target::int4 AS target,
length*estado_actual.custo AS cost
FROM arcos, estado_actual
where arcos.estado_a = estado_actual.id_ea',
438,489,false,false)) AS rota
ON
arcos.id2 = rota.edge_id) AS rota2
using unique id"
TOLERANCE 3
TOLERANCEUNITS pixels
TEMPLATE void
PROJECTION
"init=epsg:27492"
END
METADATA
"DESCRIPTION" "rota"
# "RESULT_FIELDS" "n_rua,rua,compriment"
# "RESULT_HEADERS" "Nº do Trecho de rua,Nome da Rua,Longitude(m)"
"ows_title" "Rota"
END # Metadata
CLASS
Name 'ruas'
COLOR 0 0 0
END # Class
END
The error is in the clause 'data'. Mapserver can´t load the route and i don´t know why. The query works fine in database (if I remove 'using unique id' and put 'select' before 'the_geom'.
It’s long time ago that I have used pgRouting with Mapserver, but I remember that I had to specify the SRID in DATA. Did you already look at this example in the pgRouting documentation? http://www.pgrouting.org/docs/howto/mapserver.html
I tried like that:
LAYER
NAME “rota”
STATUS DEFAULT
TYPE LINE
PROCESSING “CLOSE_CONNECTION=DEFER”
CONNECTION “user=pedro password=********** dbname=test host=localhost options=‘-c client_encoding=LATIN1’”
DATA “the_geom from
FROM arcos
JOIN
(SELECT * FROM shortest_path(’
SELECT id2 as id,
where arcos.estado_a = estado_actual.id_ea’,
ON
using unique id”
“RESULT_HEADERS” “Nº do Trecho de rua,Nome da Rua,Longitude(m)”
“ows_title” “Rota”
END # Metadata
CLASS
Name ‘ruas’
COLOR 0 0 0
END # Class
END
The error is in the clause ‘data’. Mapserver can´t load the route and i don´t know why. The query works fine in database (if I remove ‘using unique id’ and put ‘select’ before ‘the_geom’.
