I just checked the srid field in the geometry_columns. Its -1. I think that is causing the problem? I’m using the dataset of Delhi. It should run on srid=4326. How do I change it to EPSG: 4326 in my geometry column?
Hey Annu,
Something like:
UPDATE table SET the_geom=ST_SetSRID(the_geom, 4326);
Though I sometimes find this troublesome and find it easier just to
create a new column, and then populate it with the data. Something
like:
SELECT AddGeometryColumn ('table_name','new_geom', 4326,'POINT',2);
Then populate it by doing:
UPDATE table_name
SET new_geom = the_geom;
Hope this helps. I'm not an expert at all - somebody else may have a
better solution.
James
is causing the problem? I'm using the dataset of Delhi. It should run on
srid=4326. How do I change it to EPSG: 4326 in my geometry column?_______________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
select getsrid(the_geom) from xxx_table;
will tell you what the srid id is set to for a geometry column in a table
xxx_table;
update xxx_table set the_geom=setsrid(the_geom,4326)
Will set the srid value for a column called the_geom in a table called
xxx_table
You can use qgis to checked your datavalues, just ask it to import a
postgis table and will will draw information.
D.
that
