No sir. I just ran the query and it returned the following result.
VSDelhidb=# SELECT count(*) FROM roads_line where the_geom is NULL;
count
11
(1 row)
What do I do sir?
11
(1 row)
What do I do sir?
You database has 11 entries which do not have a correct geometry column,
I suspect that this may be causing you some problems.
select * from roads_line where the_geom is NULL will list all the problems
delete from roads_line where the_geom is null
will permanently remove these data items from your database.
I can not say that this is the root cause of your problem but I suspect
that its not helping you.
count
11
(1 row)What do I do sir?
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
