Hi Steve,
It has changed table name to the_network and after that to ways. Error
is same all the time. Is there something wrong in function? Or i am
missing something?
*SQL error:*
ERROR: column"’the_network’" does not exist
LINE 1: SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid...
*In statement:*
SELECT assign_vertex_id3d(’the_network’, 1, ’the_geom’, ’gid’,
'F_LEVEL', 'T_LEVEL');
Function assign_vertex_id3d is bellow
assign_vertex_id3d "geom_table" character varying, "tolerance" double
precision, "geo_cname" character varying, "gid_cname" character
varying, "source_zlevel_cname" character varying,
"target_zlevel_cname" character varying character varying plpgsql
Definition
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
DECLARE
_r record;
source_idint;
target_idint;
sridinteger;
BEGIN
BEGIN
DROP TABLE vertices_tmp;
EXCEPTION
WHEN UNDEFINED_TABLETHEN
END;
EXECUTE 'CREATE TABLE vertices_tmp (id serial)';
-- FOR _r IN EXECUTE'SELECT srid FROM geometry_columns WHERE f_table_name='''|| quote_ident(geom_table)||''';' LOOP
-- srid := _r.srid;
-- END LOOP;
srid := Find_SRID('public',quote_ident(geom_table),quote_ident(geo_cname));
EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'',''the_geom'','||srid||',''POINT'', 3)';
CREATE INDEX vertices_tmp_idxON vertices_tmpUSING GIST (the_geom);
FOR _rIN EXECUTE 'SELECT' || quote_ident(gid_cname) ||' AS id,'
||' ST_MakePoint(ST_X(StartPoint('|| quote_ident(geo_cname) ||')), ST_Y(StartPoint('|| quote_ident(geo_cname) ||')),'|| quote_ident(source_zlevel_cname) ||') AS source,'
||' ST_MakePoint(ST_X(EndPoint('|| quote_ident(geo_cname) ||')), ST_Y(EndPoint('|| quote_ident(geo_cname) ||')),'|| quote_ident(target_zlevel_cname) ||') AS target'
||' FROM' || quote_ident(geom_table)
LOOP
source_id := point_to_id3d(setsrid(_r.source, srid), tolerance);
target_id := point_to_id3d(setsrid(_r.target, srid), tolerance);
EXECUTE 'update' || quote_ident(geom_table) ||
' SET source =' || source_id ||
', target =' || target_id ||
' WHERE' || quote_ident(gid_cname) ||' =' || _r.id <http://r.id/>;
END LOOP;
RETURN 'OK';
END;
- Miroslav
2011/3/25 Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>>
network is a postgresql type so it must be quoted. So you can try
doing:
SELECT assign_vertex_id3d(’"network"’, 1, ’the_geom’, ’gid’,
This might work, but in general you might have other issues with
other stored procedures also.
You could also try changing your table name like:
alter table "network" rename to "the_network";
then reference it by the_network like:
-Steve
On 3/24/2011 6:32 PM, Miroslav Novta wrote:
Hello Dear,
I have faced a problem with assign_vertex_id3d. It is a bit
strange
error message i have get. I have explored all code i suspect
and have no
clue. Error report is network is not a column, it is a table
and it
should be a table, i have no idea why it expect it to be a column.
Here is error i get:
ERROR: column "’network’" does not exist
LINE 1: SELECT assign_vertex_id3d(’network’, 1, ’the_geom’,
’gid’, '...
In statement:
SELECT assign_vertex_id3d(’network’, 1, ’the_geom’, ’gid’,
'F_LEVEL',
'T_LEVEL');
To explain more, network is my ways table defined with iGO
standard. I
have added source and target columns according to guide
-- Add "source" and "target" column
ALTER TABLE "network" ADD COLUMN "source" integer;
ALTER TABLE "network" ADD COLUMN "target" integer;
Do you have any idea what is wrong? What have i missed?
Miroslav
2011/3/23 Stephen Woodbridge <woodbri@swoodbridge.com
> On 3/23/2011 10:23 AM, Miroslav Novta wrote:
>> Steve,
>> Thank you, I will follow your Instructions. I don't expect
a lot of
>> problems with turn restrictions because maneuvers table is
still empty
>> and will be filled after routing become functional.
>> I still have some baby problems to make pgRouting functional.
>> For example what is correct range of tolerance if i use
meters not
>> degrees in assign vertex?
> This depends on your data for example in degrees if you data
has a
resolution of 0.000001 then this is a good value to use.
> For meters, you might use 0.5 or 0.9, the best way to
evaluate this
is to look the the coordinates at the ends of to segments that
should be
connected. So:
> abs(Xa - Xb) < tolerance
> to match the two ends to the same node. If you set tolerance
too big
then it will merge close by nodes that should not be
connected. If you
set the tolerance too small it will not match nodes that should be
connected. We use tolerance to deal with floating point
numbers not
being exact like integers and can have rounding errors in the
numbers.
> -Steve
>> Miroslav
<mailto:woodbri@swoodbridge.com>>>>
>> Charles,
>> Thank you for posting that. I am glad I read the whole thread
>> because I was just about to did up my old code and dust it
off to
>> post. There is no need for that as your implementation
accurately
>> reflects mine.
>> Miroslav,
>> Regarding turn restrictions, you should search the archives
for this
>> as I have been fairly vocal about the limitations. To
summarize:
>> 1. turn restrictions only work with shooting star
>> 2. If you have multiple turn restrictions, I think you have
to enter
>> the related links multiple times, ie: once for each restriction
>> 3. IMHO, we need to rework the turn restrictions to make
adding them
>> more intuitive and easier
>> 4. before you try to implement a large number of them, I would
>> verify that you can in fact add multiple turn restrictions in a
>> trivial graph that is easy to verify if it works as expected,
>> because it is my sense that this area has not been used to
any great
>> extent.
>> -Steve
>> On 3/23/2011 7:43 AM, Charles Galpin wrote:
>> Hi Miroslav
>> This is an implementation I have been using which I made
after a
>> discussion with Stephen on this subject. It is essentially an
>> implementation of his ideas and works fine for me, but ymmv.
>> Otherwise search the email archives as I believe he posted
his here
>> at some point as well.
>> hth charles
>> On Mar 23, 2011, at 6:44 AM, Miroslav Novta wrote:
>> Hello list,
>> I want to use the assign_vertices_3d() function developed by
>> Stephen Woodbridge. I want to use it for iGO shp map
format with
>> "turn restrictions" too.
>> Is there source code and documentation available on any
public
>> repository I may access?
>> -- Function: assign_vertex_id3d(character varying, double
precision,
>> character varying, character varying, character varying,
character
>> varying)
>> -- DROP FUNCTION assign_vertex_id3d(character varying, double
>> precision, character varying, character varying, character
varying,
>> character varying);
>> CREATE OR REPLACE FUNCTION assign_vertex_id3d(geom_table
character
>> varying, tolerance double precision, geo_cname character
varying,
>> gid_cname character varying, source_zlevel_cname character
varying,
>> target_zlevel_cname character varying) RETURNS character
varying AS
>> $BODY$ DECLARE _r record; source_id int; target_id int; srid
>> integer; BEGIN
>> BEGIN DROP TABLE vertices_tmp; EXCEPTION WHEN UNDEFINED_TABLE
THEN
>> END;
>> -- FOR _r IN EXECUTE 'SELECT srid FROM geometry_columns WHERE
>> f_table_name='''|| quote_ident(geom_table)||''';' LOOP --
srid
>> := _r.srid; -- END LOOP;
>> srid :=
''the_geom'',
>> '||srid||', ''POINT'', 3)'; CREATE INDEX vertices_tmp_idx ON
>> vertices_tmp USING GIST (the_geom);
>> FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS
>> id,' ||
>> ST_Y(StartPoint('|| quote_ident(geo_cname) ||')), '||
>> quote_ident(source_zlevel_cname) ||') AS source,' || '
>> ST_Y(EndPoint('|| quote_ident(geo_cname) ||')), '||
>> quote_ident(target_zlevel_cname) ||') AS target' || ' FROM ' ||
>> quote_ident(geom_table) LOOP
tolerance);
tolerance);
>> EXECUTE 'update ' || quote_ident(geom_table) || ' SET source
>> source_id || ', target = ' || target_id || ' WHERE ' ||
>> quote_ident(gid_cname) || ' = ' || _r.id <http://r.id/>
<http://r.id/>>
<http://r.id/>>; END LOOP;
>> RETURN 'OK';
>> END; $BODY$ LANGUAGE 'plpgsql' VOLATILE STRICT COST 100; ALTER
precision,
character
>> varying) OWNER TO postgres;
>> -- Function: point_to_id3d(geometry, double precision)
>> -- DROP FUNCTION point_to_id3d(geometry, double precision);
>> CREATE OR REPLACE FUNCTION point_to_id3d(p geometry, tolerance
>> double
>> precision) RETURNS bigint AS $BODY$
>> DECLARE _r record; _id bigint; _srid integer;
>> BEGIN
>> _srid := Find_SRID('public','vertices_tmp','the_geom');
>> SELECT ST_Length3D(ST_MakeLine(the_geom,p)) AS d, id
>> INTO _r FROM vertices_tmp WHERE
>> the_geom&& Expand(p, tolerance) AND
>> ST_Length3D(ST_MakeLine(the_geom,p))< tolerance
>> ORDER BY d LIMIT 1;
>> IF FOUND THEN
>> _id:= _r.id <http://r.id/> <http://r.id/>>
<http://r.id/>>;
>> ELSE
>> INSERT INTO vertices_tmp(the_geom) VALUES (SetSRID(p,_srid));
>> _id:=lastval();
>> END IF;
>> RETURN _id;
>> FUNCTION point_to_id3d(geometry, double precision) OWNER TO
>> postgres;
>> _______________________________________________ Pgrouting-users
>> mailing list Pgrouting-users@lists.osgeo.org
<mailto:Pgrouting-users@lists.osgeo.org>
<mailto:Pgrouting-users@lists.osgeo.org>>
<mailto:Pgrouting-users@lists.osgeo.org>>>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Pgrouting-users mailing list
>> Miroslav Novta
Miroslav Novta
Miroslav Novta
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
