hi, just to keep records,
I found the latest error origin: (
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43 )
- compiler was not finding $include/postgresql/server/datatype/timestamp.h
Now I'm trying to resolve some new errors:
[ 37%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o
In file included from /usr/local/include/boost/graph/adjacency_list.hpp:247,
from
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:25:
/usr/include/boost/graph/detail/adjacency_list.hpp:2795: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp:2796: error:
explicit specialization of non-template â__gnu_cxx::hashâ
/usr/include/boost/graph/detail/adjacency_list.hpp:2803: error: âhashâ
is not a template
â__gnu_cxx::hashâ is not a template type
/usr/include/boost/graph/detail/adjacency_list.hpp:2813: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp:2823: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp: In instantiation
of âboost::detail::adj_list_any_edge_pmap::bind_<boost::adjacency_list<boost::listS,
boost::vecS, boost::directedS, boost::no_property, Vertex,
boost::no_property, boost::listS>, Vertex, boost::edge_weight_t>â:
/usr/include/boost/graph/detail/adjacency_list.hpp:2736:
instantiated from
âboost::detail::adj_list_choose_edge_pmap<boost::edge_weight_t,
boost::adjacency_list<boost::listS, boost::vecS, boost::directedS,
boost::no_property, Vertex, boost::no_property, boost::listS>,
Vertex>â
/usr/include/boost/graph/detail/adjacency_list.hpp:2743:
instantiated from
âboost::detail::adj_list_edge_property_selector::bind_<boost::adjacency_list<boost::listS,
/usr/local/include/boost/graph/properties.hpp:215: instantiated from
âboost::detail::edge_property_map<boost::adjacency_list<boost::listS,
boost::no_property, boost::listS>, boost::edge_weight_t>â
/usr/local/include/boost/graph/properties.hpp:233: instantiated from
âboost::property_map<boost::adjacency_list<boost::listS, boost::vecS,
boost::directedS, boost::no_property, Vertex, boost::no_property,
boost::listS>, boost::edge_weight_t, void>â
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:76:
instantiated from here
/usr/include/boost/graph/detail/adjacency_list.hpp:2701: error:
forming reference to void
/usr/include/boost/graph/detail/adjacency_list.hpp:2702: error:
/usr/include/boost/graph/detail/adjacency_list.hpp:2706: error:
/usr/include/boost/graph/detail/adjacency_list.hpp:2709: error:
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp: In
function âint boost_dijkstra(edge_t*, unsigned int, int, int, bool,
bool, path_element_t**, int*, char**)â:
error: no matching function for call to âget(boost::edge_weight_t,
boost_dijkstra(edge_t*, unsigned int, int, int, bool, bool,
path_element_t**, int*, char**)::graph_t&)â
from
/usr/include/boost/graph/detail/adjacency_list.hpp: In function
âtypename boost::property_map<typename Config::graph_type, Property,
void>::type boost::get(Property, boost::adj_list_helper<Config,
Base>&) [with Config =
boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
boost::no_property, boost::listS>, boost::vecS, boost::listS,
boost::listS>::config, Base =
boost::directed_graph_helper<boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
boost::listS>::config>, Property = float8 Vertex::*]â:
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:123:
/usr/include/boost/graph/detail/adjacency_list.hpp:1724: error:
invalid use of void expression
make[2]: ** [core/src/CMakeFiles/routing.dir/boost_wrapper.o] Erro 1
make[1]: ** [core/src/CMakeFiles/routing.dir/all] Erro 2
make: ** [all] Erro 2
Eduardo
2014-06-03 18:04 GMT-03:00 Eduardo Kanegae <eduardo.kanegae@gmail.com>:
thanks Steve,
I've turned off CGAL and DD options withing ccmake but now it seems
like some kind of declaration errors:
[ 12%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:22:
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43: error:
expected specifier-qualifier-list before âIntervalâ
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c: In function
âfetch_distanceâ:
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:369: error:
âorder_tâ has no member named âtoâ
For this case I think this branch could attend me, because it's a
specific application which I'll need only DARP functions and will not
use the other routing solvers.
Eduardo
2014-06-03 17:25 GMT-03:00 Stephen Woodbridge <woodbri@swoodbridge.com>:
Hi Eduardo,
I have not tried to build the DARP branch ever, but the error you are
getting has something to do with CGAL and the driving distance code. I think
there was a cmake option to disable this. Maybe something like:
cmake -DWITH_DD=NO .
To get it to compile and work in pgRouting 2.x you would need to migrate the
code into the 2.x source tree and update the cmake files so it gets included
and tweak the SQL code. Basically make it follow the pattern setup for the
other code.
-Steve
On 6/3/2014 3:49 PM, Eduardo Kanegae wrote:
hi there,
I'm running PostGIS 2.0.4 on PostgreSQL 8.4.12 (CentOS 6.3) and I'm
trying to build pgRouting 1.05 (the DARP branch) but it gives me the
following error:
[ 7%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
[ 14%] Building CXX object
extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.o
Linking CXX shared library ../../../lib/librouting_tsp.so
[ 14%] Built target routing_tsp
[ 21%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
[ 28%] Building CXX object
extra/darp/src/CMakeFiles/routing_darp.dir/darp_solver.o
Linking CXX shared library ../../../lib/librouting_darp.so
[ 28%] Built target routing_darp
Scanning dependencies of target routing_dd
[ 35%] Building C object
extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
[ 42%] Building CXX object
extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o
/usr/local/include/CGAL/internal/Exact_type_selector.h:39,
from /usr/local/include/CGAL/Filtered_kernel.h:35,
from
/usr/local/src/pgrouting-1.05-darp/extra/driving_distance/src/alpha_drivedist.cpp:35:
/usr/local/include/CGAL/Mpzf.h: In function âCGAL::Mpzf
CGAL::Mpzf_square(const CGAL::Mpzf&)â:
/usr/local/include/CGAL/Mpzf.h:709: error: âmpn_sqrâ was not declared
in this scope
make[2]: **
[extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o]
Erro 1
make[1]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all]
Erro 2
Here's my "ccmake" config params:
Boost_DIR /usr/lib64/boost
Boost_INCLUDE_DIR /usr/include
Boost_LIBRARY_DIRS /usr/lib
CGAL_INCLUDE_DIR /usr/local/include
CGAL_LIBRARIES /usr/local/lib/libCGAL.so
CMAKE_AR /usr/bin/ar
CMAKE_BACKWARDS_COMPATIBILITY 2.4
CMAKE_BUILD_TYPE
CMAKE_COLOR_MAKEFILE ON
CMAKE_CXX_COMPILER /usr/bin/c++
CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS_DEBUG -g
CMAKE_CXX_FLAGS_MINSIZEREL -Os -DNDEBUG
CMAKE_CXX_FLAGS_RELEASE -O3 -DNDEBUG
CMAKE_CXX_FLAGS_RELWITHDEBINFO -O2 -g
CMAKE_C_COMPILER /usr/bin/gcc
CMAKE_C_FLAGS
CMAKE_C_FLAGS_DEBUG -g
CMAKE_C_FLAGS_MINSIZEREL -Os -DNDEBUG
CMAKE_C_FLAGS_RELEASE -O3 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO -O2 -g
CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_MINSIZE
CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELWITH
CMAKE_EXPORT_COMPILE_COMMANDS OFF
CMAKE_INSTALL_PREFIX /usr/local
CMAKE_LINKER /usr/bin/ld
CMAKE_MAKE_PROGRAM /usr/bin/gmake
CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS_DEBU
CMAKE_MODULE_LINKER_FLAGS_MINS
CMAKE_MODULE_LINKER_FLAGS_RELE
CMAKE_MODULE_LINKER_FLAGS_RELW
CMAKE_NM /usr/bin/nm
CMAKE_OBJCOPY /usr/bin/objcopy
CMAKE_OBJDUMP /usr/bin/objdump
CMAKE_RANLIB /usr/bin/ranlib
CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS_DEBU
CMAKE_SHARED_LINKER_FLAGS_MINS
CMAKE_SHARED_LINKER_FLAGS_RELE
CMAKE_SHARED_LINKER_FLAGS_RELW
CMAKE_SKIP_INSTALL_RPATH OFF
CMAKE_SKIP_RPATH OFF
CMAKE_STRIP /usr/bin/strip
CMAKE_USE_RELATIVE_PATHS OFF
CMAKE_VERBOSE_MAKEFILE OFF
EXECUTABLE_OUTPUT_PATH
GAUL_INCLUDE_DIR /usr/local/include
GAUL_LIBRARIES /usr/local/lib/libgaul.so
GAUL_UTIL_LIBRARIES /usr/local/lib/libgaul_util.so
LIBRARY_OUTPUT_PATH /usr/lib64/pgsql
PGROUTING_CORE_INCLUDE_DIR
POSTGRESQL_EXECUTABLE /usr/bin/postgres
POSTGRESQL_INCLUDE_DIR /usr/include/pgsql/server
POSTGRESQL_LIBRARIES /usr/lib64/pgsql
WITH_CGAL ON
WITH_DARP ON
WITH_DD ON
WITH_GAUL ON
WITH_PostgreSQL ON
WITH_TSP ON
As far as I know DARP module is only available at this 1.05 darp
branch. Or should I try to build pgRouting 2 + PostGIS 2.1.3 +
PostgreSQL 9.x ?
ps.:
a) CGAL installed is 4.4
b) GAUL installed is version 0.1849
thanks for any help.
Eduardo Patto Kanegae
http://www.webmapit.com | @webmapit
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
