Work that out first. Read the Documentation and the workshop.
If you table is big it will take a while. Get this working first and then
we can talk about how to speed it up if you need that.
lol. Now we're talking about the same issue!
I could run n x n queries but this would not be very efficient as I'd
like to have a more "automatic" solution.
I already thought about function and looping but as being a complete
newbie on looping and writing functions this seems quite hard to solve
for myself.
Maybe you've got a hint?
thanks
carsten
2014-03-14 15:53 GMT+01:00 Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>>:
On Fri, Mar 14, 2014 at 11:42 PM, Carsten Hogertz
<carsten.hogertz@gmail.com <mailto:carsten.hogertz@gmail.com>>
wrote:
Hi Daniel,
thanks for your eMail.
Well, I think it's not a 1-n calculation. IMHO it's a 1-1
calculation,right?
So I don't know how to calculate the distance for each row of
the routing_pair table.
Well, you need to run this query for each row. So with n rows you
need n queries.
If you use standard shortest path function you need to run "n x n"
queries.
You may want to write a custom function, which makes first a select
of all records in your table and then loops through these records.
Or don't I still understand the problem?
Daniel
Thanks
Carsten
2014-03-14 15:33 GMT+01:00 Daniel Kastl <daniel@georepublic.de
On Fri, Mar 14, 2014 at 11:26 PM, Carsten Hogertz
<mailto:carsten.hogertz@gmail.com>> wrote:
Maybe to clearify.
I've got the following two tables:
Table at_2po_4pgr with the columns:
id integer NOT NULL,
osm_id bigint,
osm_name character varying,
osm_meta character varying,
osm_source_id bigint,
osm_target_id bigint,
clazz integer,
flags integer,
source integer,
target integer,
km double precision,
kmh integer,
cost2 double precision,
reverse_cost double precision,
x1 double precision,
y1 double precision,
x2 double precision,
y2 double precision,
geom_way geometry(LineString,4326)
and Table routing_pair with the columns:
id integer,
h_key integer,
lat_htl double precision,
lon_htl double precision,
source integer,
geom_htl geometry(Point,4326),
lat_bhf double precision,
lon_bhf double precision,
target integer,
geom_bhf geometry(Point,4326)
The routing_pair table hold three important information:
ID
SOURCE
TARGET
All columns are filled (source + target are calculated
from at_2po_4pgr.
The task seems to be quite simple: I want for each row
from the routing_pair the distance between soure +
target (and if possible its geom).
Could you please help me how to solve this?
Hi Carsten,
There is a function named kDijkstra and it allows you to
calculate all paths from one node to many:
http://docs.pgrouting.org/2.0/en/src/kdijkstra/doc/index.
html#pgr-kdijkstra
If something is not clear with the page above, feel free to
ask.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
<mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.info
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@
georepublic.de>
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.
osgeo.org>
