I am trying to convert a shapefile of linestrings into a suitable form for pgroute. The type of issue that I am getting is that from a casual look its looks fine, but if you drill down in to the map, you find there are some line segments should connect, but they don’t due to the way that the data was entered.
Q. Has anybody attempt this type of thing before and what if any solutions did they find ?
Dave.
Hi Dave,
Have you tried:
https://docs.pgrouting.org/2.6/en/pgr_nodeNetwork.html
Its has some issues, but does a reasonable work for pgRouting purposes.
Fixing the geometry would be using postGIS
On Thu, May 17, 2018 at 2:47 PM, Dave Potts <mrdapotts@gmail.com> wrote:
Dave.
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
I tried this and got an error message to the effect missing column
med_proj=# \d tmp;
Table “public.tmp”
Column | Type | Collation | Nullable | Default
On 17 May 2018 at 21:35, Vicky Vergara <vicky@georepublic.de> wrote:
Hi Dave,
Have you tried:
Dave.
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Dave:
your table “tmp” does only has id and the_geom columns
med_proj=# \d tmp;
Table “public.tmp”
id | integer | | not null | nextval(‘tmp_id_seq’::regclass)
the_geom | geometry(Geometry,3857) | | |
med_proj=# \d tmp_noded;
Table “public.tmp_noded”
id | integer | | not null | nextval(‘tmp_noded_id_seq’::regclass)
old_id | bigint | | |
sub_id | bigint | | |
source | bigint | | |
target | bigint | | |
Invoking this, should put the results in tmp_noded, which according to the above and the manual at https://docs.pgrouting.org/2.6/en/pgr_nodeNetwork.html has all the right column
Doing this
med_proj=# select pgr_createTopology(‘tmp’,1);
Given an error, I don’t think there is anything wrong with the functions, it most be my table layout, but according to the documents,everything is correct.
NOTICE: PROCESSING:
NOTICE: pgr_createTopology(‘tmp’, 1, ‘the_geom’, ‘id’, ‘source’, ‘target’, rows_where := ‘true’, clean := f)
NOTICE: Performing checks, please wait …
NOTICE: ----> PGR ERROR in pgr_createTopology: Column source not found
HINT: ----> Check your column name
NOTICE: Unexpected error raise_exception
pgr_createtopology
FAIL
any ideas what I am doing wrong ?
Dave.
Hi Dave,
Have you tried:
Dave.
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Got it sorted, thanks for the help
On 19 May 2018 at 15:47, Vicky Vergara <vicky@georepublic.de> wrote:
Dave:
med_proj=# \d tmp;
Table “public.tmp”
Doing this
NOTICE: PROCESSING:
pgr_createtopology
FAIL
Dave.
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Hi Dave,
Have you tried:
Dave.
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
