Hello list
Thanks to those that tried to help me
Problem found
I am calling the function driving_distance from the file
routing_dd_wrappers.sql at line 78.
This is my input data
0 X 3000.000000 Y 3000.000000
1 X 3000.000000 Y 3000.000000
2 X 3000.000000 Y 3000.000000
3 X 3000.000000 Y 3000.000000
4 X 4000.000000 Y 2000.000000
5 X 4000.000000 Y 2000.000000
If you look at it careful, you will notice less than 3 different values
which is the source of the problem. The Alpha_shape_2 routine blow up
with a core dump unless you have 3 or more different alpha values in it.
This little problem is not described in the CGAL support.
Attempts are made to catch it in the route source, but these fail because
it overlooks the problem of the same data appearing twice.
ie do
Will pass the current checks.
I think we need to add the following code at line 166 of alpha_drivedist.cpp
Alpha_shape_2 A(points.begin(), points.end(),
coord_type(10000),
Alpha_shape_2::GENERAL);
// check that there are more than 3 values in A otherwise you get a core
// dump
if( A.number_of_alphas() < 3){
*err_msg=(char*)"Driving distance requires at least 3 different
distinct values";
return -1;
std::vector<Segment> segments;
std::vector<Segment> result;
ie get the alpha_shape_2 code to check the number of distinct values, if
its less than 3 issue a message but do not core dump and take the database
down.
Dave.
Dave Potts wrote:
Now problems with the LD_LIBRARY_PATH, but just in case of errors i
removed the extra copies of libroute.so, nochanges.
As I said the problem seems to be alpha_shape routine.
Dave.
Stephen Woodbridge wrote:
Dave,
This sounds like you might have multiple librouting.so look here:
/usr/lib/postgresql/8.4/lib/librouting.so
change the version to match yours.
Also try:
locate librouting.so
ldd /usr/lib/postgresql/8.4/lib/librouting.so
and make sure you do not have multiple copies of dependent libraries
loaded. Like in /usr/lib and /usr/local/lib
See if you can determine if msg_rsv is getting a null pointer passed to
it. But anything is possible if the loading is messed up.
-Steve
On 2/9/2012 12:57 AM, Dave Potts wrote:
While calling the driving_dstance function from
routing_dd_wrappers.sql,
line 78
My postgres server back DIES
I tried rebuilding from source and attaching and instance of gdb to the
server process as pg_backend_pid();
By doing something like gdb /usr/lib/postgresql/9.1/bin/postgres pid
Gdb claims that server process dies in msg_rsv
I think I am using the wrong image because none of the DD code is being
used.
By turning on debug statments, I managed to strace the problem to the
c/c++ interface between alpha_shape
I get lots of prints until the routine
ret = alpha_shape(vertices, total_tuples, res, res_count,&err_msg);
is called.
I tried puting in calls like
write(2,"Hello\n",6); and elog(ERROR, "Hello world" ,"eeee"); as the
first line in alpha_shape, nothing evers gets printed
So I suspect it might be a linking issue!
Is this a known problem?
What process image should I be attaching gbc to?
regards
Dave
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
