Ross,
I confirmed the pgrouting 2.0.0 binaries don't work with latest postgresql
9.2 64-bit but the pgrouting 2.1 beta works.
If you can give that a try that would be great, since we are very close to
releasing pgRouting 2.1 anyway and would like some testers.
However I am working on recompiling 2.0.0 for newer postgresql 9.2. Should
have sometime tomorrow.
Note that with pgRouting 2.0 the .dll is now versioned, so you would need to
do an ALTER EXTENSION .. to upgrade a 2.0.
Since it is versioned, the 2.1 and 2.0 can coexist on the same server as
long as they are in different databases.
Regina
-----Original Message-----
Sent: Monday, August 10, 2015 12:29 PM
To: 'pgRouting users mailing list' <pgrouting-users@lists.osgeo.org>
Subject: RE: [pgrouting-users] Could not load library librouting.dll error
Yes. The binaries get created by Winnie and I test and package to push to
stack builder and also copy to http://download.osgeo.org/postgis/windows/
So they are always available on her first and released on osgeo
[mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of McDonaldR
Sent: Monday, August 10, 2015 12:01 PM
Subject: Re: [pgrouting-users] Could not load library librouting.dll error
Thank you Regina
It would be good to test that. Will the binaries also be available from
winnie.postgis.net? We operate behind a firewall and cannot use the stack
builder.
Ross
[mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: 10 August 2015 16:14
I had to upgrade the gcc I am using for building with PostgreSQL 9.2 and
also they made a change in PostgreSQL 9.2 micros around 9.2.5 or so that is
incompatible with older postgresql 9.2 that forced a recompile of some
things.
I'll build a new PostgreSQL 9.2 and pgRouting 2.0.0 and test with latest 9.2
64-bit. If it goes well I'll push to application stack builder (PostgreSQL
9.2 PostGIS 2.1.8 and pgRouting 2.0.0)
Let me spin up a 9.2 64-bit to test with and see what's up.
Regina
Sent: Monday, August 10, 2015 10:59 AM
To: pgRouting users mailing list <pgrouting-users@lists.osgeo.org>
Thanks for the reply, Dave
I've tried with the PATH set to both:
Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Syst
em32
\WindowsPowerShell\v1.0\;D:\Php;D:\Php\ext;D:\PostgreSQL\9.2\bin;D:\PostgreS
QL\9.2\lib
And:
em32
I wonder if it is something to do with the way PostgreSQL, PostGIS and
PgRouting are compiled? Looking at
http://winnie.postgis.net/download/windows/pg92/buildbot/ there are versions
compiled with GCC4.8 and others with something else. I've tried all the
64bit binary versions there with no luck.
Ross
dave.potts@pinan.co.uk
Sent: 10 August 2015 15:28
Hi
What is the environmental variable path set to ?
You can get its value by opening a dos window and typing set
This variable lists the folders that an application will search through to
find library files.
You can change its value by selecting control panel-->Adminstrative Tools->
Right click on computer select properties-> select advanced system settings
and the envrionment variable button is on the lower right hand side
The value should be a list off folders to search seperated by a ; character.
Dave
#> Hello list,
I am running 64bit PostgreSQL 9.2.13 with PostGIS 2.1.7 on Windows
Server
2008 R2. I have pgRouting installed (2.0.0 build 40, hash 567ac3b,
boost
1.46.1)
I am getting an error when trying to use pgRouting.
[ERROR: could not load library "D:/PostgreSQL/9.2/lib/librouting.dll":
The specified procedure could not be found.
SQL state: 58P01]
SQL state error 58P01 is UNDEFINED FILE.
Using dependency walker it tells me that librouting.dll cannot find
libgcc_s_sjlj-1.dll and libstdc++-6.dll and postgres.exe. These files
all exist in the \bin folder of my PostgreSQL install. The PgRouting
files are all installed in the \lib folder.
I get the error when using both the PgAdmin SQL pane and the pgRouting
Layer plugin in QGIS.
Any pointers or suggestions appreciated.
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT
Division | Angus Council, Angus House, Orchardbank Business Park,
Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E:
mcdonaldr@angus.gov.uk<mailto:mcdonaldr@angus.gov.uk>
This message is strictly confidential. If you have received this in
error, please inform the sender and remove it from your system. If
received in error you may not copy, print, forward or use it or any
attachment in any way. This message is not capable of creating a legal
contract or a binding representation and does not represent the views
of Angus Council. Emails may be monitored for security and network
management reasons. Messages containing inappropriate content may be
intercepted. Angus Council does not accept any liability for any harm
that may be caused to the recipient system or data on it by this
message
or any attachment.
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
This message is strictly confidential. If you have received this in error,
please inform the sender and remove it from your system. If received in
error you may not copy, print, forward or use it or any attachment in any
way. This message is not capable of creating a legal contract or a binding
representation and does not represent the views of Angus Council. Emails may
be monitored for security and network management reasons. Messages
containing inappropriate content may be intercepted. Angus Council does not
accept any liability for any harm that may be caused to the recipient system
or data on it by this message or any attachment.
