I want to create a geometry table with the result of this query:
SELECT * FROM shortest_path
('SELECT gid AS id,
source::int4 AS source,
target::int4 AS target,
lenght::float8 AS cost
FROM passeios',
438,
439,
false,
false)
(‘SELECT gid AS id,
FROM passeios’,
438,
439,
false,
false)
also, if you only need a temporary table, you can use:
CREATE TABLE [options, such as temporary] table_name> as SELECT * FROM . . . .
On Thu, Mar 15, 2012 at 5:22 PM, James David Smith
<james.david.smith@gmail.com> wrote:
Unless I'm missing something, you just need to change the first line to
SELECT * INTO new_table FROM shortest_path( ...... etc.
James
On 16 Mar 2012 00:14, "Pedro Costa" <pedrocostaarma@sapo.pt> wrote:
Hello to all,
Can anybody help me to solve this problem:
('SELECT gid AS id,
FROM passeios',
438,
439,
false,
false)
The “core” shortest path function only returns a list of edge id’s with costs.
To include geometry information you need to link again to the original table or just use one of the wrapper functions: http://workshop.pgrouting.org/chapters/shortest_path.html#wrapper
(‘SELECT gid AS id,
FROM passeios’,
438,
439,
false,
false)
FROM passeios
JOIN
(SELECT * FROM shortest_path('
SELECT gid AS id,
start_id::int4 AS source,
end_id::int4 AS target,
FROM passeios',
438,
439,
false,
false)) AS route
ON
network.gid = route.edge_id;
James
On 16 March 2012 10:16, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Pedro,
The "core" shortest path function only returns a list of edge id's with
costs.
Daniel
On Fri, Mar 16, 2012 at 7:10 PM, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
Thanks to Talin and James but the problem is that the new table has no
geometry. My difficulty is to give the table geometry. How I do that?
thanks
On 16-03-2012 00:22, James David Smith wrote:
James
Hello to all,
('SELECT gid AS id,
FROM passeios',
438,
439,
false,
false)
I'm taking the first steps with pg_routing.
I'll use it for my dissertation.
thanks
On 16-03-2012 10:24, James David Smith wrote:
Pedro,
Daniel is right. This should do it?
FROM passeios
JOIN
SELECT gid AS id,
FROM passeios',
438,
439,
false,
false)) AS route
ON
James
On 16 March 2012 10:16, Daniel Kastl<daniel@georepublic.de> wrote:
Hi Pedro,
costs.
Daniel
thanks
James
On 16 Mar 2012 00:14, "Pedro Costa"<pedrocostaarma@sapo.pt> wrote:
Hello to all,
('SELECT gid AS id,
FROM passeios',
438,
439,
false,
false)
