Hi List, this is my first post in this list so first of all I want to say thanks to the pgrouting team for this project.
Now the question:
I followed an example from the tutorial wrote by David Techer. With a previous version of pgrouting everything was fine (I tried it a couple of years ago) but now I have
ubuntu maverick plus pgrouting 1.05 from georepublic repository and im getting weird results.
This path is traversing the roundabout in opposite direction (6,5,4 edges instead of 1,2,3 edges) . (Im using the original file pgrouting_wr.sql from the tutorial so it was expected to get the same result).
routing2=# select * from shortest_path_shooting_star ('select gid as id, source, target, cost, reverse_cost,x1,y1,x2,y2, to_cost, rule from wr', 20, 8, true, true);
vertex_id | edge_id | cost
15 | 20 | 48.3246366252935
16 | 18 | 38.0005743220152
13 | 17 | 39.2224758594282
14 | 15 | 39.4286821133412
11 | 16 | 29.9822270236865
12 | 13 | 38.6094358307609
10 | 12 | 25.9044654619518
8 | 11 | 60
2 | 9 | 40
1 | 7 | 53.8753258085636
4 | 6 | 12.8311604873812
29 | 5 | 10.6864968606796
27 | 4 | 14.2572101668807
6 | 8 | 62.5380849791951
If I exchange the starting and end node the I get the same result!! (4,5,6 edges)
routing2=# select * from shortest_path_shooting_star ('select gid as id, source, target, cost, reverse_cost,x1,y1,x2,y2, to_cost, rule from wr', 8, 20, true, true);
5 | 8 | 62.5380849791951
6 | 4 | 14.2572101668807
27 | 5 | 10.6864968606796
29 | 6 | 12.8311604873812
4 | 7 | 53.8753258085636
1 | 9 | 40
2 | 10 | 33.4201752293529
10 | 14 | 29.5829181472758
14 | 17 | 39.2224758594282
13 | 18 | 38.0005743220152
16 | 20 | 48.3246366252935
Im getting strange results with Dijkstra too like pgrouting is choosing cost with 10000 values
Definitely Im doing something wrong but dont know what.
Any help would be very appreciated.
Best,
Jose
